Error in nextcloud using truenas scale
I am getting an error in my log files that says opendir(/Nextcloud/): Failed to open directory: Permission denied at /var/www/html/lib/private/Files/Storage/Local.php#130
Every minute I get this error
This is the log file I get
{“reqId”:“tT0vFOGOP50mpczffGAq”,“level”:3,“time”:“2025-03-04T01:08:03+00:00”,“remoteAddr”:“172.71.159.72”,“user”:“xxxxxxxx”,“app”:“PHP”,“method”:“PROPFIND”,“url”:“/remote.php/dav/files/xxxxxxx/Nextcloud-Storage”,“message”:“opendir(/Nextcloud/): Failed to open directory: Permission denied at /var/www/html/lib/private/Files/Storage/Local.php#130”,“userAgent”:“Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.22631 ClientArchitecture: x86_64 OsArchitecture: x86_64)”,“version”:“31.0.0.18”,“data”:{“app”:“PHP”},“id”:“67c652780e026”}
Thank you for any and all help
Check your External Storage configuration (both personal and global).
How do I go about doing this were does the URL come from and what username and password do I use and do I have set something up. Please help thank you
I was able to get the external storage to work but I am still getting errors in my log files
Log Entry
{“reqId”:“T7wNdiUqe66GmoM9TxaC”,“level”:3,“time”:“2025-03-06T18:33:54+00:00”,“remoteAddr”:“198.41.227.174”,“user”:“Richard”,“app”:“PHP”,“method”:“PROPFIND”,“url”:“/remote.php/dav/files/xxxxxxx/Nextcloud-Storage”,“message”:“opendir(/Nextcloud/): Failed to open directory: Permission denied at /var/www/html/lib/private/Files/Storage/Local.php#130”,“userAgent”:“Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.22631 ClientArchitecture: x86_64 OsArchitecture: x86_64)”,“version”:“31.0.0.18”,“data”:{“app”:“PHP”},“id”:“67c9ea95bfe95”}
Thank you for any help
The one that appears to be failing per the log is called /Nextcloud-Storage and is a Local type External Storage. Make sure to check both Personal and Administration levels of External Storage too.
I think there is a problem with my installation. When I click on the check mark next to the external storage in the admin account it says I need to authenticate with my password but if I click the nextcloud admin password it says the password is wrong and I know it is right because I log in with same password but if I type in the password, it just sits there saying confirming and does nothing. I am also having a problem with the mail server not working it will not send email. I am lost. Thank you for your help
