I have nextcloud installed behind a Apache proxy in a docker container. The Apache self delivers files using HTTPS (letsencrypt certificate). The communication between Apache and the Docker container is not HTTPS secured.
The docker-container’s apache port (where nextcloud runs) is emitting the port 1234.
Is it possible to run run the password app with this configuration?
<VirtualHost *:443>
ProxyPass / http://localhost:1234/ retry=1
ProxyPassReverse / http://localhost:1234/
ProxyPreserveHost On
ProxyVia On
RequestHeader set X-Forwarded-Proto 'https' env=HTTPS
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains; preload"
</VirtualHost>
