Nextcloud version 14.0.1
Operating system and version Ubuntu 18.04.1
Apache or nginx version Apache 2.4.29)
PHP version 7.2.10
While attempting to update to 14.0.1 I get a message that states “an error has occurred, click here to reload the page.” Site is still in Maintenance Mode so I get a maintenance mode message. If I go into the config file and turn off maintenance mode I start back at the update page. I’m stuck in a loop at this point.
The output of the details on the update error page:
Preparing update
Set log level to debug
Turned on maintenance mode
Updating database schema
Updated database
Checking for update of app "cloud_federation_api" in appstore
An error occurred.
Is this the first time you’ve seen this error?
Yes
I can’t access the web UI. I’ll be happy to post logs if anyone tells me were to grab them from.
I have made no special changes to this, it’s generic.
'instanceid' => 'NO',
'passwordsalt' => 'NO',
'secret' => 'DOUBLE NO',
0 => 'DOMAIN NAME',
'datadirectory' => 'SERVER PATH',
'overwrite.cli.url' => 'DOMAIN NAME',
'version' => '13.0.6.1',
'dbname' => 'NOPE',
'dbhost' => 'SOME MORE NOPE',
'dbuser' => 'NO',
'dbpassword' => 'NO,
'maintenance' => true,
'theme' => '',
'loglevel' => 0,
Preparing update
Updated database
An error occurred. 'updater.release.channel' => 'stable',
'updater.secret' => 'NAH',
