The log file is full of the same error messages.
- Default encryption app is activated.
- Server-side encryption is activated in the settings.
- Default encryption module is selected in the settings.
- Storage encryption is activated in the settings.
Nextcloud version: 11.0.3
Operating system and version: Linux 3.10.0-514.16.1.el7.x86_64
Apache or nginx version: Apache
PHP version: 5.6.26
Is this the first time you’ve seen this error?:
Yes
Steps to replicate:
- Login as admin.
- Open the log file.
Errors in the error log, see below.
The output of your Nextcloud log:
Error Default encryption module not loaded 2017-06-11T23:44:34+0200
Error Default encryption module not loaded 2017-06-11T23:44:33+0200
(etc.)
