Sorry to hear youāre facing problems.
The community help forum (help.nextcloud.com) is for home and non-enterprise users. Support is provided by other community members on a best effort / āas availableā basis. All of those responding are volunteering their time to help you.
If youāre using Nextcloud in a business/critical setting, paid and SLA-based support services can be accessed via portal.nextcloud.com where Nextcloud engineers can help ensure your business keeps running smoothly.
- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
[/details]
Some or all of the below information will be requested if it isnāt supplied; for fastest response please provide as much as you can. ![]()
Nextcloud Hub 10 version (e.g., 31.0.7):
- Operating system and version _:
- Synology DSM 7.2.2.
- 2.4.63
- PHP version (e.g, 8.3):
- waarschijnlijk 8.3
- Is this the first time youāve seen this error? (Yes / No):
-Yes - When did this problem seem to first start?
- At first security check
- Nextcloud AIO
- No
In installed nextcloud on my synology nas and everything seems to work fine. Security control did a few checks and came op with error. I have no idea what to do about it. Can somebody help me? I can make a raw log file, but I donāt know where that is stored. I cantāt find the nextcloud instance in my docker folder.
After installing nextcloud all seems to work fine. In the admin panel a security check is performed and this generates a fatal problem. The problem keeps repeating.
- At opening the overview page the instances of this error are counting
I can make a csv log file from the container an a screenshot. I can save the raw file somewhere, but I don't
know where to find it. The nextcloud files are not in mij docker directory.
PASTE
PASTE HERE
Synology NAS 218+
I don't know where to find these files. They are not in my docker folder, and I can't access the root easily on a synology nas.
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
