Nextcloud version (eg, 15.0.7):
Operating system and version (11.2 -release Jail in Freenas):
Apache or nginx version (Apache/2.4.39 (FreeBSD)
PHP version (eg, 7.2.18):
- I dont know
nection_check GuzzleHttp\Exception\ConnectException: cURL error 7: Failed to connect to www.nextcloud.com port 443: Operation timed out (see http://curl.haxx.se/libcurl/c/libcurl-errors.html)
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php - line 149:
GuzzleHttp\Handler\CurlFactory::createRejection(GuzzleHttp\H ... l}, { errno: 7,e ... 0})
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php - line 102:
GuzzleHttp\Handler\CurlFactory::finishError(GuzzleHttp\H ... {}, GuzzleHttp\H ... l}, GuzzleHttp\H ... {})
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php - line 43:
GuzzleHttp\Handler\CurlFactory::finish(GuzzleHttp\H ... {}, GuzzleHttp\H ... l}, GuzzleHttp\H ... {})
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/Proxy.php - line 28:
GuzzleHttp\Handler\CurlHandler->__invoke("*** sensiti ... *", "*** sensiti ... *")
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/Proxy.php - line 51:
GuzzleHttp\Handler\Proxy::GuzzleHttp\Handler\{closure}("*** sensiti ... *")
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php - line 37:
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php - line 30:
GuzzleHttp\PrepareBodyMiddleware->__invoke("*** sensiti ... *", "*** sensiti ... *")
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php - line 70:
GuzzleHttp\Middleware::GuzzleHttp\{closure}("*** sensiti ... *")
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php - line 107:
GuzzleHttp\RedirectMiddleware->__invoke("*** sensiti ... *", "*** sensiti ... *")
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php - line 72:
GuzzleHttp\RedirectMiddleware->checkRedirect(GuzzleHttp\Psr7\Request {}, "*** sensiti ... *", "*** sensiti ... *")
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/promises/src/FulfilledPromise.php - line 39:
GuzzleHttp\RedirectMiddleware->GuzzleHttp\{closure}("*** sensiti ... *")
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php - line 47:
GuzzleHttp\Promise\FulfilledPromise::GuzzleHttp\Promise\{closure}("*** sensiti ... *")
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 246:
GuzzleHttp\Promise\TaskQueue->run(true)
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 223:
GuzzleHttp\Promise\Promise->invokeWaitFn()
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 267:
GuzzleHttp\Promise\Promise->waitIfPending()
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 225:
GuzzleHttp\Promise\Promise->invokeWaitList()
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 62:
/usr/local/www/apache24/data/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php - line 131:
GuzzleHttp\Promise\Promise->wait()
/usr/local/www/apache24/data/nextcloud/lib/private/Http/Client/Client.php - line 161:
GuzzleHttp\Client->request("get", "http://www.nextcloud.com/", { verify: "/ ... e})
/usr/local/www/apache24/data/nextcloud/settings/Controller/CheckSetupController.php - line 157:
OC\Http\Client\Client->get("http://www.nextcloud.com/")
/usr/local/www/apache24/data/nextcloud/settings/Controller/CheckSetupController.php - line 140:
OC\Settings\Controller\CheckSetupController->isSiteReachable("www.nextcloud.com")
/usr/local/www/apache24/data/nextcloud/settings/Controller/CheckSetupController.php - line 696:
OC\Settings\Controller\CheckSetupController->isInternetConnectionWorking()
/usr/local/www/apache24/data/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 166:
OC\Settings\Controller\CheckSetupController->check()
/usr/local/www/apache24/data/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 99:
OC\AppFramework\Http\Dispatcher->executeController(OC\Settings\ ... {}, "check")
/usr/local/www/apache24/data/nextcloud/lib/private/AppFramework/App.php - line 118:
OC\AppFramework\Http\Dispatcher->dispatch(OC\Settings\ ... {}, "check")
/usr/local/www/apache24/data/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47:
OC\AppFramework\App::main("OC\\Setting ... r", "check", OC\AppFramew ... {}, { _route: "s ... "})
<<closure>>
OC\AppFramework\Routing\RouteActionHandler->__invoke({ _route: "s ... "})
/usr/local/www/apache24/data/nextcloud/lib/private/Route/Router.php - line 297:
call_user_func(OC\AppFramew ... {}, { _route: "s ... "})
/usr/local/www/apache24/data/nextcloud/lib/base.php - line 987:
OC\Route\Router->match("/settings/ajax/checksetup")
/usr/local/www/apache24/data/nextcloud/index.php - line 42:
OC::handleRequest()
GuzzleHttp\Exception\ConnectException: cURL error 28: Operation timed out after 150002 milliseconds with 0 out of 0 bytes received (see http://curl.haxx.se/libcurl/c/libcurl-errors.html)
GuzzleHttp\Handler\CurlFactory::createRejection(GuzzleHttp\H ... l}, { errno: 28, ... 4})
<<closure>>
OC::handleRequest()
Hi, do you know what could be causing this errors?
