Nextcloud version (eg, 12.0.2):
17.0.0
Operating system and version (eg, Ubuntu 17.04):
CentOS 7 64-bit
Apache or nginx version (eg, Apache 2.4.25): nginx-1.12.2
PHP version (eg, 7.1): 7.2
When I try to upload files via the web interface, the upload fails with the error ‘Not enough free space’. This error is a misdiagnosis; the data directory is mounted on a dedicated 2TB drive with only ~50GB used. Even small files (20 bytes) fail. Uploading via the desktop client works fine. Research lead me to some past posts here but none seemed to end in a resolution.
Y
- Install Nextcloud under CentOS/ MariaDB / PHP 7.2
- Attempt to upload a file of any size via the web interface (files -> + -> upload file).
No server logs
Everything is working fine
'instanceid' => '***REDACTED***',
'passwordsalt' => '***REDACTED***',
'secret' => '***REDACTED***',
0 => 'cloud.caturria.ca',
'apps_paths' => array(
array(
'path'=> '/home/nextcloud/nextcloud/apps',
'url' => '/apps',
'writable' => true,
'datadirectory' => '/home/nextcloud/data',
'version' => '17.0.0.9',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:3306',
'dbuser' => 'nextcloud',
'dbpassword' => '***REDACTED***',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'caturria.ca',
'mail_smtphost' => 'mail.caturria.ca',
'mail_smtpport' => '587',
'mail_smtpsecure' => 'tls',
'mail_smtpauthtype' => 'PLAIN',
'mail_smtpauth' => 1,
'mail_smtpname' => 'cloud@caturria.ca',
'mail_smtppassword' => '***REDACTED***',
'memcache.local' => '\OC\Memcache\Redis',
'redis' => [
'host' => 'localhost', // can also be a unix domain socket: '/tmp/redis.sock'
'port' => 6379,
'timeout' => 0.0,
'password' => '***REDACTED***', // Optional, if not defined no password will be used.
***No events generated in /var/log/nginx/error.log***
Some other details you might find useful:
Definitely not a capacity issue:
[root@caturria ~]# df -h /home/nextcloud/data
Filesystem Size Used Avail Use% Mounted on
/dev/vdb1 1.8T 62G 1.7T 4% /home/nextcloud/data
/dev/vda1 394G 75G 300G 20% /
[root@caturria ~]#
I’ve also included the Nginx server block configuration:
server{
listen 80;
server_name cloud.caturria.ca;
add_header Strict-Transport-Security "max-age=15552000; includeSubDomains;" always;
add_header Cache-Control "public, max-age=15778463";
add_header X-Robots-Tag none;
add_header Referrer-Policy no-referrer;
return 301 https://$host$uri;
server{
listen 443 ssl http2;
ssl_certificate /etc/letsencrypt/live/caturria.ca/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/caturria.ca/privkey.pem;
ssl_protocols TLSv1.2;
ssl_session_cache shared:SSL:1m;
ssl_session_timeout 10m;
ssl_prefer_server_ciphers on;
ssl_ciphers ECDH+AESGCM:ECDH+AES256:ECDH+AES128:DH+3DES:!ADH:!AECDH:!MD5;
add_header X-Frame-Options SAMEORIGIN;
root /home/nextcloud/nextcloud;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
rewrite ^/.well-known/webfinger /public.php?service=webfinger last;
return 301 $scheme://$host:$server_port/remote.php/dav;
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
location / {
rewrite ^ /index.php$request_uri;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^(.+\.php)(.*)$ {
fastcgi_split_path_info ^(.+\.php)(.*)$;
fastcgi_pass unix:/var/run/php-fpm-cloud.sock;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $request_filename;
include fastcgi_params;
fastcgi_param HTTPS on;
# Avoid sending the security headers twice
# Enable pretty urls
fastcgi_intercept_errors on;
location ~ ^\/(?:updater|oc[ms]-provider)(?:$|\/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js, css and map files
location ~ \.(?:css|js|woff2?|svg|gif|map)$ {
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap)$ {
# Optional: Don't log access to other assets
access_log off;
Lastly, the php-fpm configuration:
[cloud]
user = nextcloud
group = nextcloud
listen = /var/run/php-fpm-cloud.sock
listen.owner = nginx
listen.group = nginx
php_admin_value[session.save_handler] = files
php_admin_value[session.save_path] = /home/nextcloud/.session
php_admin_value[disable_functions] =
php_admin_value[memory_limit] = 512M
php_admin_value[opcache.interned_strings_buffer] = 8
php_admin_value[opcache.max_accelerated_files] = 10000
php_admin_value[opcache.memory_consumption] = 128
php_admin_flag[opcache.save_comments] = 1
php_admin_flag[opcache.revalidate_freq] = 1
php_admin_value[upload_max_filesize]=1g
php_admin_value[post_max_size]=1g
php_admin_flag[allow_url_fopen] = off
pm = dynamic
pm.max_children = 10
pm.start_servers = 2
pm.min_spare_servers = 1
pm.max_spare_servers = 3
chdir = /home/nextcloud/nextcloud
clear_env = no
I’ve been attempting to troubleshoot this and researching for the last two days to no avail. Thank you very much for your time.
Thanks,
Jordan.
