Bonjour,
Je suis sur la derniĂšre version de NextCloud mais je rencontre un problĂšme avec lâapplication âTrashâ (lâapplications pour rĂ©cupĂ©rer ses fichiers supprimĂ©s), avec plusieurs comptes jâai une erreur qui apparait dans les logs mâempĂȘchant de voir la corbeille je vous les joint:
TypeError: Return value of OCA\Files_Trashbin\Sabre\AbstractTrash::getSize() must be of the type int, float returned
- /var/www/NEXTCLOUD/apps/files_trashbin/lib/Sabre/PropfindPlugin.php - line 85:OCA\Files_Trashbin\Sabre\AbstractTrash->getSize()
- /var/www/NEXTCLOUD/3rdparty/sabre/dav/lib/DAV/PropFind.php - line 96:OCA\Files_Trashbin\Sabre\PropfindPlugin->OCA\Files_Trashbin\Sabre{closure}(â*** sensiti ⊠*â)
- /var/www/NEXTCLOUD/apps/files_trashbin/lib/Sabre/PropfindPlugin.php - line 86:Sabre\DAV\PropFind->handle(â{http://owncloud.org/ns}sizeâ, Closure {})
- /var/www/NEXTCLOUD/3rdparty/sabre/event/lib/WildcardEmitterTrait.php - line 89:OCA\Files_Trashbin\Sabre\PropfindPlugin->propFind(Sabre\DAV\PropFind {}, OCA\Files_Tr ⊠{})
- /var/www/NEXTCLOUD/3rdparty/sabre/dav/lib/DAV/Server.php - line 1063:Sabre\DAV\Server->emit(âpropFindâ, [ Sabre\DAV\ ⊠}])
- /var/www/NEXTCLOUD/3rdparty/sabre/dav/lib/DAV/Server.php - line 989:Sabre\DAV\Server->getPropertiesByNode(Sabre\DAV\PropFind {}, OCA\Files_Tr ⊠{})
- /var/www/NEXTCLOUD/3rdparty/sabre/dav/lib/DAV/Server.php - line 1678:Sabre\DAV\Server->getPropertiesIteratorForPath(âtrashbin/Jordan/trashâ, [ "{http://n ⊠"], 1)
- /var/www/NEXTCLOUD/3rdparty/sabre/dav/lib/DAV/Server.php - line 1661:Sabre\DAV\Server->writeMultiStatus(Sabre\Xml\Wr ⊠]}, Generator {}, false)
- /var/www/NEXTCLOUD/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 363:Sabre\DAV\Server->generateMultiStatus(Generator {}, false)
- /var/www/NEXTCLOUD/3rdparty/sabre/event/lib/WildcardEmitterTrait.php - line 89:Sabre\DAV\CorePlugin->httpPropFind(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
- /var/www/NEXTCLOUD/3rdparty/sabre/dav/lib/DAV/Server.php - line 474:Sabre\DAV\Server->emit(âmethod:PROPFINDâ, [ Sabre\HTTP ⊠}])
- /var/www/NEXTCLOUD/3rdparty/sabre/dav/lib/DAV/Server.php - line 251:Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
- /var/www/NEXTCLOUD/3rdparty/sabre/dav/lib/DAV/Server.php - line 319:Sabre\DAV\Server->start()
- /var/www/NEXTCLOUD/apps/dav/lib/Server.php - line 332:Sabre\DAV\Server->exec()
- /var/www/NEXTCLOUD/apps/dav/appinfo/v2/remote.php - line 35:OCA\DAV\Server->exec()
- /var/www/NEXTCLOUD/remote.php - line 167:require_once(â/var/www/na ⊠pâ)
