log
{"reqId":"eTIPKunzyi1ZxCHJ9M1A","level":3,"time":"2022-03-05T10:18:25+00:00","remoteAddr":"192.168.0.61","user":"--","app":"index","method":"GET","url":"/login","message":"The requested uri(/login) cannot be processed by the script '/nextcloud/index.php')","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:97.0) Gecko/20100101 Firefox/97.0","version":"23.0.2.1","exception":{"Exception":"Exception","Message":"The requested uri(/login) cannot be processed by the script '/nextcloud/index.php')","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/base.php","line":944,"function":"getRawPathInfo","class":"OC\\AppFramework\\Http\\Request","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Request.php","Line":770,"CustomMessage":"--"}}
{"reqId":"eTIPKunzyi1ZxCHJ9M1A","level":0,"time":"2022-03-05T10:18:25+00:00","remoteAddr":"192.168.0.61","user":"--","app":"maps","method":"GET","url":"/login","message":"/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:97.0) Gecko/20100101 Firefox/97.0","version":"23.0.2.1"}
{"reqId":"eTIPKunzyi1ZxCHJ9M1A","level":1,"time":"2022-03-05T10:18:25+00:00","remoteAddr":"192.168.0.61","user":"--","app":"no app in context","method":"GET","url":"/login","message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:97.0) Gecko/20100101 Firefox/97.0","version":"23.0.2.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/html/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Defaults.php","line":280,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/Defaults.php","line":177,"function":"getLongFooter","class":"OC_Defaults","type":"->"},{"file":"/var/www/html/nextcloud/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":180,"args":["/var/www/html/nextcloud/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":179,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":210,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":331,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":74,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"eTIPKunzyi1ZxCHJ9M1A","level":1,"time":"2022-03-05T10:18:25+00:00","remoteAddr":"192.168.0.61","user":"--","app":"no app in context","method":"GET","url":"/login","message":"Unable to generate a URL for the named route \"dashboard.dashboard.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:97.0) Gecko/20100101 Firefox/97.0","version":"23.0.2.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"dashboard.dashboard.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/html/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Defaults.php","line":280,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/Defaults.php","line":177,"function":"getLongFooter","class":"OC_Defaults","type":"->"},{"file":"/var/www/html/nextcloud/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":180,"args":["/var/www/html/nextcloud/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":179,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":210,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":331,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":74,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"eTIPKunzyi1ZxCHJ9M1A","level":1,"time":"2022-03-05T10:18:25+00:00","remoteAddr":"192.168.0.61","user":"--","app":"no app in context","method":"GET","url":"/login","message":"Unable to generate a URL for the named route \"mail.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:97.0) Gecko/20100101 Firefox/97.0","version":"23.0.2.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"mail.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/html/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Defaults.php","line":280,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/Defaults.php","line":177,"function":"getLongFooter","class":"OC_Defaults","type":"->"},{"file":"/var/www/html/nextcloud/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":180,"args":["/var/www/html/nextcloud/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":179,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":210,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":331,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":74,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"eTIPKunzyi1ZxCHJ9M1A","level":1,"time":"2022-03-05T10:18:25+00:00","remoteAddr":"192.168.0.61","user":"--","app":"no app in context","method":"GET","url":"/login","message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:97.0) Gecko/20100101 Firefox/97.0","version":"23.0.2.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/html/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Defaults.php","line":280,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/Defaults.php","line":177,"function":"getLongFooter","class":"OC_Defaults","type":"->"},{"file":"/var/www/html/nextcloud/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":180,"args":["/var/www/html/nextcloud/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":179,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":210,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":331,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":74,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"eTIPKunzyi1ZxCHJ9M1A","level":1,"time":"2022-03-05T10:18:25+00:00","remoteAddr":"192.168.0.61","user":"--","app":"no app in context","method":"GET","url":"/login","message":"Unable to generate a URL for the named route \"gpxpod.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:97.0) Gecko/20100101 Firefox/97.0","version":"23.0.2.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"gpxpod.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/html/nextcloud/apps/gpxpod/lib/AppInfo/Application.php","line":62,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/NavigationManager.php","line":115,"function":"OCA\\Gpxpod\\AppInfo\\{closure}","class":"OCA\\Gpxpod\\AppInfo\\Application","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Defaults.php","line":280,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/Defaults.php","line":177,"function":"getLongFooter","class":"OC_Defaults","type":"->"},{"file":"/var/www/html/nextcloud/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":180,"args":["/var/www/html/nextcloud/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":179,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":210,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":331,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":74,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
