Hello guys,
I’m using rancher for managing my k8s cluster and workloads.
I’ve tried installing nextcloud and everything went fine. I can access it by visiting my machines IP+Port but not using my ingress. I’m always getting the error “err_too_many_redirects”.
I’m using the linuxserver/nextcloud
Container Port 80 = Listening Port 8003
Container Port 443 = Listening Port 9003
My ingress cloud.mydomain.com
points to workload “nextcloud” on port 80.
My nginx configuration (default one)
upstream php-handler {
server 127.0.0.1:9000;
server {
listen 80;
listen [::]:80;
server_name cloud.mydomain.com;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /config/keys/cert.crt;
ssl_certificate_key /config/keys/cert.key;
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
# could take several months.
add_header X-Robots-Tag none;
add_header X-Frame-Options "SAMEORIGIN";
add_header Referrer-Policy no-referrer;
root /config/www/nextcloud/;
# display real ip in nginx logs when connected through reverse proxy via docker network
set_real_ip_from 172.0.0.0/8;
real_ip_header X-Forwarded-For;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
return 301 $scheme://$host:$server_port/remote.php/dav;
location = /.well-known/webfinger {
return 301 $scheme://$host:$server_port/public.php?service=webfinger;
location = /.well-known/host-meta {
return 301 $scheme://$host:$server_port/public.php?service=host-meta;
location = /.well-known/host-meta.json {
return 301 $scheme://$host:$server_port/public.php?service=host-meta-json;
client_max_body_size 10G;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
location / {
rewrite ^ /index.php;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+|.+\/richdocumentscode\/proxy)\.php(?:$|\/) {
fastcgi_split_path_info ^(.+?\.php)(\/.*|)$;
set $path_info $fastcgi_path_info;
include /etc/nginx/fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^\/(?:updater|oc[ms]-provider)(?:$|\/) {
try_files $uri/ =404;
index index.php;
location ~ \.(?:css|js|woff2?|svg|gif|map)$ {
add_header Cache-Control "public, max-age=15778463";
# topic first.
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap|mp4|webm)$ {
access_log off;
My config.php
'overwrite.cli.url' => 'https://cloud.mydomain.com',
'datadirectory' => '/data',
0 => '192.168.178.100:9003',
1 => 'cloud.mydomain.com',
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
'version' => '19.0.1.1',
'dbname' => '',
'dbhost' => '',
'dbuser' => '',
'dbpassword' => '',
I really could need some help.
