Administrator said the problem fixed?
May be you would report there
After having the same issue and trying to figure out a fix I finally found what was wrong in my instance.
I use the linuxserver/nextcloud:latest image with Swag as a reverse proxy. I wrote a script that would deal with any installation steps besides running docker-compose that also copies a few config files.
Solution in my case: Have nextcloud create a fresh /config/www/nextcloud/config/config.php
file.
An attempt of an explanation:
The installation script copied my old working config file with the old values of
'instanceid' => 'string',
'passwordsalt' => 'STRING',
'secret' => 'STRING',
That must have messed up the login process resulting in an infinite loop. If any of you still have the redirect problem try generating a new config file and see if that solves the problem.
