I’m facing mutliple issues with the encryption module :
- I’m discovering mutiple files that i can’t open : I get this error :
fclose() expects parameter 1 to be resource, string given at /var/www/nextcloud/lib/private/Files/Storage/Wrapper/Encryption.php#758
OCP\Encryption\Exceptions\GenericEncryptionException: Bad Signature
I’m not even sure i can track those files that can’t be open. Is there a command line that allow me to check bad signature ?
- I’m also getting this error :
OC\Encryption\Exceptions\DecryptionFailedException: Can not decrypt this file, probably this is a shared file. Please ask the file owner to reshare the file with you.
This are shared files that i, as user, have created, so i don’t how i can resshare a key to myself ??
- Considering all the difficulties and error i’m facing with encryption, i wanted to disable it before it’s too late. But i 'm not able to disable encryption. When i’m running encryption:decrypt-all or only with my user , i’m getting :
Files for following users couldn’t be decrypted,
maybe the user is not set up in a way that supports this operation : USER
I wanted to use this command encryption:enable-master-key but i’m afraid to loose data since most of my data are encrypted.
Thanx for the help
Nextcloud version (eg, 12.0.2): Nextcloud 14
Operating system and version (eg, Ubuntu 17.04): Ubuntu server 18.04
Apache or nginx version (eg, Apache 2.4.25): APACHE
PHP version (eg, 7.1): 7.1
