Greetings,
We have a little problem on embedding Nextcloud into an iframe of another webapplication (Angular: http://localhost:4201).
The authentication method for nextcloud is: Nextcloud authentication method - Login Flow v2
We changed all the recommended headers within the .htaccess file:
Header always add Access-Control-Allow-Origin "http://localhost:4201"
Header always set Access-Control-Allow-Headers "origin, x-requested-with, content-type, authorization, depth, multistatus"
Header always set Access-Control-Allow-Methods "PUT, GET, POST, DELETE, OPTIONS, PROPFIND"
Header always set Access-Control-Allow-Credentials "true"
<IfModule mod_headers.c>
<IfModule mod_setenvif.c>
<IfModule mod_fcgid.c>
SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
</IfModule>
<IfModule mod_proxy_fcgi.c>
SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
</IfModule>
<IfModule mod_lsapi.c>
</IfModule>
</IfModule>
<IfModule mod_env.c>
Header onsuccess unset Content-Security-Policy
Header always set Content-Security-Policy "frame-ancestors 'self' http://localhost:4201;form-action 'self' http://localhost:4201;"
Header onsuccess unset X-Content-Security-Policy
# Header always set X-Content-Security-Policy "default-src 'self';base-uri 'none';manifest-src 'self';frame-ancestors *;"
Header always set X-Content-Security-Policy "frame-ancestors 'self' http://localhost:4201;form-action 'self' http://localhost:4201;"
Header onsuccess unset Referrer-Policy
Header always set Referrer-Policy "no-referrer"
Header onsuccess unset X-Content-Type-Options
Header always set X-Content-Type-Options "nosniff"
Header onsuccess unset X-Frame-Options
# Header set X-Frame-Options "SAMEORIGIN"
Header always set X-Frame-Options "allow-from http://localhost:4201"
Header onsuccess unset X-Permitted-Cross-Domain-Policies
Header always set X-Permitted-Cross-Domain-Policies "none"
# Header always set X-Permitted-Cross-Domain-Policies "master-only" - not working
Header onsuccess unset X-Robots-Tag
Header always set X-Robots-Tag "noindex, nofollow"
Header onsuccess unset X-XSS-Protection
Header always set X-XSS-Protection "1; mode=block"
SetEnv modHeadersAvailable true
</IfModule>
# Add cache control for static resources
<FilesMatch "\.(css|js|svg|gif|png|jpg|ico|wasm|tflite)$">
Header set Cache-Control "max-age=15778463"
</FilesMatch>
<FilesMatch "\.(css|js|svg|gif|png|jpg|ico|wasm|tflite)(\?v=.*)?$">
Header set Cache-Control "max-age=15778463, immutable"
</FilesMatch>
# Let browsers cache WOFF files for a week
<FilesMatch "\.woff2?$">
Header set Cache-Control "max-age=604800"
</FilesMatch>
</IfModule>
# PHP 7.x
<IfModule mod_php7.c>
php_value mbstring.func_overload 0
php_value default_charset 'UTF-8'
php_value output_buffering 0
SetEnv htaccessWorking true
</IfModule>
</IfModule>
# PHP 8+
<IfModule mod_php.c>
</IfModule>
</IfModule>
<IfModule mod_mime.c>
AddType image/svg+xml svg svgz
AddType application/wasm wasm
AddEncoding gzip svgz
</IfModule>
<IfModule mod_dir.c>
DirectoryIndex index.php index.html
</IfModule>
<IfModule pagespeed_module>
ModPagespeed Off
</IfModule>
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{HTTP_USER_AGENT} DavClnt
RewriteRule ^$ /remote.php/webdav/ [L,R=302]
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.*) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
RewriteRule ^\.well-known/(?!acme-challenge|pki-validation) /index.php [QSA,L]
RewriteRule ^(?:\.(?!well-known)|autotest|occ|issue|indie|db_|console).* - [R=404,L]
RewriteCond %{REQUEST_METHOD} OPTIONS
RewriteRule ^(.*)$ $1 [L,R=200]
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 /
ErrorDocument 404 /
Options -MultiViews
RewriteRule ^core/js/oc.js$ index.php [PT,E=PATH_INFO:$1]
RewriteRule ^core/preview.png$ index.php [PT,E=PATH_INFO:$1]
RewriteCond %{REQUEST_FILENAME} !\.(css|js|svg|gif|png|html|ttf|woff2?|ico|jpg|jpeg|map|webm|mp4|mp3|ogg|wav|wasm|tflite)$
RewriteCond %{REQUEST_FILENAME} !/core/ajax/update\.php
RewriteCond %{REQUEST_FILENAME} !/core/img/(favicon\.ico|manifest\.json)$
RewriteCond %{REQUEST_FILENAME} !/(cron|public|remote|status)\.php
RewriteCond %{REQUEST_FILENAME} !/ocs/v(1|2)\.php
RewriteCond %{REQUEST_FILENAME} !/robots\.txt
RewriteCond %{REQUEST_FILENAME} !/(ocm-provider|ocs-provider|updater)/
RewriteCond %{REQUEST_URI} !^/\.well-known/(acme-challenge|pki-validation)/.*
RewriteCond %{REQUEST_FILENAME} !/richdocumentscode(_arm64)?/proxy.php$
RewriteRule . index.php [PT,E=PATH_INFO:$1]
RewriteBase /
SetEnv front_controller_active true
DirectorySlash off
</IfModule>
</IfModule>
</IfModule>
Also we made the recommended changed in ContentSecurityPolicy.php
- just to ensure (some things are overwritten by .htaccess
protected $allowedFrameDomains = [
'\'self\'',
'localhost:4201',
'devel-wk.ecmind',
/** @var array Domains which can embed this Nextcloud instance */
protected $allowedFrameAncestors = [
'\'self\'',
'localhost:4201',
'devel-wk.ecmind',
/** @var array Domains from which web-workers can be loaded */
protected $allowedWorkerSrcDomains = [];
/** @var array Domains which can be used as target for forms */
protected $allowedFormActionDomains = [
'\'self\'',
// 'localhost:4201', - has no effect
This is a screen of the initial request - which works fine:
The current result is:
Expected in this case should be more something like a “Connect to your account” site with login-button to grant access i think.
Hopefully somebody has an idea what the problem could be, that an “Access denied” appears in iframe while the same (src-)URL is working as expected within a new window/tab.
Kind regards
