A problem occurred while sending the email. Please revise your settings. (Error: Connection could not be established with host domain.com [ #0] Log data: ++ Starting Swift_SmtpTransport !! Connection could not be established with host domain.com [ #0] (code: 0)
When I try to send email from basic settings it gives me this error
Can anyone help?
example
longer
example
here
Nextcloud version (eg, 12.0.2):
Operating system and version (eg, Ubuntu 17.04):
PHP version (eg, 7.1):
PASTE HERE
PASTE HERE
PASTE HERE
