…OCP\AppFramework\QueryException: Could not resolve operation! Class operation does not exist
The full error messages are:
[no app in context] Error: OCP\AppFramework\QueryException: Could not resolve operation! Class operation does not exist at <>
- /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php line 115
OC\AppFramework\Utility\SimpleContainer->resolve(“operation”) - /var/www/nextcloud/lib/private/ServerContainer.php line 150
OC\AppFramework\Utility\SimpleContainer->query(“operation”, true) - /var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php line 389
OC\ServerContainer->query(“operation”, true) - /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php line 77
OC\AppFramework\DependencyInjection\DIContainer->query(“operation”) - /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php line 100
OC\AppFramework\Utility\SimpleContainer->buildClass(ReflectionClass … "}) - /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php line 115
OC\AppFramework\Utility\SimpleContainer->resolve(“OCA\FilesAutom … r”) - /var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php line 415
OC\AppFramework\Utility\SimpleContainer->query(“OCA\FilesAutom … r”) - /var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php line 386
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback(“OCA\FilesAutom … r”) - /var/www/nextcloud/apps/files_automatedtagging/lib/AppInfo/Application.php line 43
OC\AppFramework\DependencyInjection\DIContainer->query(“OCA\FilesAutom … r”) - /var/www/nextcloud/apps/files_automatedtagging/appinfo/app.php line 23
OCA\FilesAutomatedTagging\AppInfo\Application->registerHooksAndListeners() - /var/www/nextcloud/lib/private/legacy/app.php line 266
require_once("/var/www/nextcl … p") - /var/www/nextcloud/lib/private/legacy/app.php line 155
OC_App::requireAppFile(“files_automatedtagging”) - /var/www/nextcloud/lib/private/Updater.php line 383
OC_App::loadApp(“files_automatedtagging”) - /var/www/nextcloud/lib/private/Updater.php line 255
OC\Updater->doAppUpgrade() - /var/www/nextcloud/lib/private/Updater.php line 131
OC\Updater->doUpgrade(“18.0.4.2”, “18.0.3.0”) - /var/www/nextcloud/core/Command/Upgrade.php line 257
OC\Updater->upgrade() - /var/www/nextcloud/3rdparty/symfony/console/Command/Command.php line 255
OC\Core\Command\Upgrade->execute(Symfony\Componen … {}, Symfony\Componen … {}) - /var/www/nextcloud/3rdparty/symfony/console/Application.php line 915
Symfony\Component\Console\Command\Command->run(Symfony\Componen … {}, Symfony\Componen … {}) - /var/www/nextcloud/3rdparty/symfony/console/Application.php line 272
Symfony\Component\Console\Application->doRunCommand(OC\Core\Command\ … }}, Symfony\Componen … {}, Symfony\Componen … {}) - /var/www/nextcloud/3rdparty/symfony/console/Application.php line 148
Symfony\Component\Console\Application->doRun(Symfony\Componen … {}, Symfony\Componen … {}) - /var/www/nextcloud/lib/private/Console/Application.php line 214
Symfony\Component\Console\Application->run(Symfony\Componen … {}, Symfony\Componen … {}) - /var/www/nextcloud/console.php line 99
OC\Console\Application->run() - /var/www/nextcloud/occ line 11
require_once("/var/www/nextcloud/console.php")
at 2020-04-24T06:45:39+02:100:
and
[no app in context] Error: OCP\AppFramework\QueryException: Could not resolve OCA\GroupFolders\Versions\VersionsBackend! Class OCA\GroupFolders\Versions\VersionsBackend does not exist at <>
OC\AppFramework\Utility\SimpleContainer->resolve(“OCA\GroupFolde … d”) - /var/www/nextcloud/lib/private/ServerContainer.php line 150
OC\AppFramework\Utility\SimpleContainer->query(“OCA\GroupFolde … d”, true) - /var/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php line 123
OC\ServerContainer->query(“OCA\GroupFolde … d”) - /var/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php line 104
OCA\Files_Versions\AppInfo\Application->loadBackend({@attributes: {f … "}) - /var/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php line 82
OCA\Files_Versions\AppInfo\Application->registerVersionBackends() - /var/www/nextcloud/lib/private/ServerContainer.php line 107
OCA\Files_Versions\AppInfo\Application->__construct() - /var/www/nextcloud/lib/private/ServerContainer.php line 133
OC\ServerContainer->getAppContainer(“files_versions”, “Files_Versions”) - /var/www/nextcloud/apps/files_versions/appinfo/app.php line 24
OC\ServerContainer->query(“OCA\Files_Vers … n”) - /var/www/nextcloud/lib/private/legacy/app.php line 266
OC_App::requireAppFile(“files_versions”) - /var/www/nextcloud/lib/private/Updater.php line 383
OC_App::loadApp(“files_versions”) - /var/www/nextcloud/lib/private/Updater.php line 255
at 2020-04-24T06:45:39+02:00
I upgraded via Updater App in NC
after upgrade i let maintenance:mode --on because using the command line occ
i did
- sudo -u www-data php occ upgrade (check)
- sudo -u www-data php occ db:add-missing-indices (check)
- … occ db:convert-filecache-bigint (check)
- … occ maintenance:mimetype:update-db (check)
- … occ maintenance:mimetype:update-js (check)
- … occ maintenance:mode --off
- … occ maintenance:repair
all done! All green. No errors in command shell.
