Drag & Drop Issue v28.0.2
I have upgraded my nextcloud to 28.0.2, and finally the drag & drop worked. However, when I drag multiple files, it will only upload the first file, no error occured in admin logging.
  • 1 file is okay
  • multiple files drag & drop will only upload the first file.
  • uploading using +new button is okay.
Hi @Kang,
Thanks, I can reproduce this exactly, and I remember this bug now.
macOs: 13.0 (22A380)
Browser: Arc 1.28.0 (45831)
Nextcloud Version: 28.0.2
Apache/2.4.57 (Debian)
PHP 8.2.7
There people in github already wating on a fix
kind regards
sambilanet
Hi, I report same problem.
It is possible drag and drop folder with subfolder but NOT multiple files.
Please patch it ASAP, copying is absolute basic feature :grinning:
Thanks Jan
Same issue here, also 28.0.2. Only 1 file will go through.
Same issue here.
Same issue here on 28.0.2
