When I login with my account, drag and drop from folders in windows to nextcloud (using chrome), works fine. However, if I create a share link (with a password), and use that link, drag and drop does not appear to work to upload either folders or files.
Is this an expected behavior difference between share links and the normal files app when logged in normally?
