Goodday,
I am wondering would it be possible to show the draft emails in the draft folder directly.
When I make a draft (or multiple) the folder drafts, when I click on the bullets/settings, will tell me there an notifcation that there are 2 draft emails but they are not yet shown in the folder so I cannot finish these emails.
It takes quitte long before it synces with email server and download the drafts.
That is strange, when I make them in nextcloud, and nextcloud can also notify me there are 2 drafts, it should show them directly in the folder drafts right?
Many thanks, Tijmen
Sounds like a bug. I think itβs slow for you as the sync of the mailbox happens in the background and is only done every 30s. That is the time it takes max until you see the drafts, I assume.
