Hi and thanks to welcome me in this forum. I’m new here and please forgive me if I forget important things in this post.
I’ll try to give you as many details as I can, but as a rookie, I may won’t find important things. Please tell me…
[/details]
Nextcloud version : 20.0.4
Operating system and version : unknown ;( I’m running NC on a web mutual server hosted by Planet Hoster (The World) and let him work as it should, so I don’t know the inside… Maybe what says my admin panel : Linux 3.10.0-962.3.2.lve1.5.36.el7.x86_64 x86_64
PHP version : 7.4.13
Memory limit 512MB
Max execution time : 3600
Upload max size : 128MB
(All this are default and I fear to change the defauts…)
Database : mysql Version 10.2.36, size 4.6MB
This is a fesh NC installation and everything almost work fine except 2 issues (one here, a second in another post).
- When I try to upload several files, I get an error saying that there is an problem uploading and that the destination folder doesn’t exist anymore. For example, with 20 Mo jpgs, I’m able to upload two of them at the same time, but it fails if I try 3 or more. So it is impossible to upload full folder in one step.
- When I try to download large folders, I get an error after 150 - 200 Mo of the zip file download. It does work with smaller folders
Is this the first time you’ve seen this error? : Yes, but as I’m new… I’ve always got it (tried 3 installs from zero and everytime the same thing)
Issue of upload
- bring a folder with many documents in the interface and several Mo of data
- or bring several files of several Mo each
Issue of download - download a folder with arround 300 Mo of data
I'm unable to find this outup :(
'instanceid' => 'xxx',
'passwordsalt' => 'xxxx',
'secret' => 'xxxx',
0 => 'loeilduciel.fr',
'datadirectory' => 'xxx',
'version' => '20.0.4.0',
'overwrite.cli.url' => 'xxx',
'dbname' => 'xxx',
'dbhost' => 'localhost',
'dbtableprefix' => 'xx',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'default_language' => 'fr',
'skeletondirectory' => '',
'enabledPreviewProviders' => [
'OC\Preview\PNG',
'OC\Preview\JPEG',
'OC\Preview\GIF',
'OC\Preview\HEIC',
'OC\Preview\BMP',
'OC\Preview\XBitmap',
'OC\Preview\MP3',
'OC\Preview\TXT',
'OC\Preview\MarkDown',
'OC\Preview\OpenDocument',
'OC\Preview\Krita',
'OC\Preview\TIFF',
Sorry, I can't find it...
