Domain connection problems
Hello I have been trying to connect my nextcloud to my domain but every time it just throws out the default apache2 site instead of nextcloud.
I did try to make a nextcloud.conf and enable it but everytime I did it it just ended up breaking the whole docker container and I had to re make it.
If you need more info I will gladly provide it.
have you tried accessing your NC locally, using http://localhost:8080/ from your hostsystem or http://localP.of.hostsystem:8080/ ?
usually dockerimages should come without any mistakes so I think there somehow is a setting-wrong.
If you are thinking about installing NC as docker have you put thought into using NC AiO (it’s also dockerized)? it helps you step-by-step to get a NC-Server running.
