If I use S3 as primary storage work? Also will th content be encrypted on S3?
If you use S3 encryption, yes. Talking about AWS S3.
This week there was a complain here that turning on nextcloud e2e with S3 will cause a performance issue. You may use the forums search function. There is also a link to my playbook that will give you an easy way to setup a test system.
