[Docker + Traefik Reverse Proxy + Subdirectory + NextCloud]-Configuration Problems
After I get the container up and running with “docker compose up -d” I add the file “rpsubdir.config.php” to the /var/www/html/config-Folder with following content:
<?php $CONFIG = array ( "overwritehost" => "example.com", "overwriteprotocol" => "http", "overwritewebroot" => "/subfolder", 'overwrite.cli.url' => 'http://example.com/subfolder', 'htaccess.RewriteBase' => '/subfolder', 'proxy' => 'http://example.com', );
My problem:
unless I type
https://example.com/subfolder/index.php” I will not be able to complete the setup since he is always trying to jump back to “http://example.com/index.php” afterwards. Why is that?
When the installation is finished he loads the directory overview with a big white window in the middle saying “content can not be shown”(I guess a banner or logo?) and if I try to navigate somewhere I always get an error since he is changing the path to something like “https://example.com/subfolder/apps/…” if I write it then like this “https://example.com/subfolder/index.php/apps/…” it sort of works…
I have this container running on a QNAP NAS with Traefik as reverse proxy in front of Nextcloud and https enforced with SSL handled by the proxy.
Thanks in advance!
Same problem to me!
Any help please?
same problem here, any advice ?
