- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
12.4.0
Windows Server - Docker Desktop
No idea, inside the install script
Cloudflare tunnel
- PHP version (e.g, 8.3):
Yes
While installing it via the official script
Docker
Cloudflare, but only the tunnel without any blocking signin methods.
- Install the app via this script (added the skip validation because i use cludflaretunnel)
docker run --init
–sig-proxy=false --name nextcloud-aio-mastercontainer
–restart always -p 80:80
-p 8080:8080 -p 8443:8443
-p 11000:11000 -e APACHE_PORT=11000
-e SKIP_DOMAIN_VALIDATION=true -v nextcloud_aio_mastercontainer:/mnt/docker-aio-config
-v //var/run/docker.sock:/var/run/docker.sock:ro `
ghcr.io/nextcloud-releases/all-in-one:latest
- Once installed i follow all steps after i skip the domain validation.
- I go to the url that points to the 8080 adres, and i see this, and nothing changes no matter how long i wait or if i restart the whole stack in Docker.
Not possible
Chrome
Apache
NoneApps
- Adding: I have lso tried to point the tunnel to port 1100 instead of 8080, but that breaks it and the page will not show. What is the issue here? Why do those containers stay stuck on Starting?
