I do have an issue with Docker and Collabora. Your help is very appreciated as I invested already a big bunch of time into it. Thanks already in advance for looking into my issue and your hints how to get collabora running.
I run an Odroid-XU4 with Ubuntu 16.04.4 LTS (GNU/Linux 4.14.47-132 armv7l) with Nextcloud 13.0.4.
I tried to install Collabora on the same Odroid to boost up my Nextcloud functionality, unfortunately without success.
I always get a “Internal Server Error” when trying to open a document in Nextcloud:
The server was unable to complete your request.
If this happens again, please send the technical details below to the server administrator.
Technical details
Remote Address: xx.xx.xx.xx
Request ID: XXXXXXXXXXXXXXXXX
The installation was done basically according https://nextcloud.com/collaboraonline/, but I tried to modify a few things as it was not working.
I tried to install docker from two different sources, but I wasn’t successful with both packages:
Package docker.io
Package docker-ce as I suspected that docker.io maybe not fit to my hardware (armhf).
sudo curl -fsSL https://download.docker.com/linux/$(. /etc/os-release; echo "$ID")/gpg | sudo apt-key add -
sudo add-apt-repository "deb [arch=armhf] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
sudo apt update
sudo apt install docker-ce
sudo docker pull collabora/code
sudo docker run -t -d -p 127.0.0.1:9980:9980 -e 'domain=cloud\\.example\\.com' --restart always --cap-add MKNOD collabora/code
The hello-world docker container seems to work.
I also tried different ways for the storage driver:
- Without change
- Edit the file /etc/systemd/system/docker.service and replace ExecStart=/usr/bin/dockerd -H fd:// with ExecStart=/usr/bin/dockerd --storage-driver=overlay2 -H fd://
according https://fribeiro.org/tech/2018/02/13/collabora-docker-nextcloud/ - Create a new file under this directory:
sudo nano /etc/systemd/system/docker.service.d/DeviceMapper.conf
Paste the following text into the file:
[Service]
ExecStart=
ExecStart=/usr/bin/dockerd --storage-driver=devicemapper -H fd://
According https://www.linuxbabe.com/cloud-storage/integrate-collabora-online-server-nextcloud-ubuntu-16-04
The log of nextcloud says the following:
Error GuzzleHttp\Exception\ServerException: Server error response [url] https://office.domain.tld/hosting/discovery [status code] 503 [reason phrase] Service Unavailable
/var/www/cloudsub.domain.tld/3rdparty/guzzlehttp/guzzle/src/Subscriber/HttpError.php - line 32: GuzzleHttp\Exception\RequestException create(Object(GuzzleHttp\Message\Request), Object(GuzzleHttp\Message\Response))
/var/www/cloudsub.domain.tld/3rdparty/guzzlehttp/guzzle/src/Event/Emitter.php - line 108: GuzzleHttp\Subscriber\HttpError->onComplete(Object(GuzzleHttp\Event\CompleteEvent), 'complete')
/var/www/cloudsub.domain.tld/3rdparty/guzzlehttp/guzzle/src/RequestFsm.php - line 91: GuzzleHttp\Event\Emitter->emit('complete', Object(GuzzleHttp\Event\CompleteEvent))
/var/www/cloudsub.domain.tld/3rdparty/guzzlehttp/guzzle/src/RequestFsm.php - line 132: GuzzleHttp\RequestFsm->__invoke(Object(GuzzleHttp\Transaction))
/var/www/cloudsub.domain.tld/3rdparty/react/promise/src/FulfilledPromise.php - line 25: GuzzleHttp\RequestFsm->GuzzleHttp\{closure}(*** sensitive parameters replaced ***)
/var/www/cloudsub.domain.tld/3rdparty/guzzlehttp/ringphp/src/Future/CompletedFutureValue.php - line 55: React\Promise\FulfilledPromise->then(Object(Closure), NULL, NULL)
/var/www/cloudsub.domain.tld/3rdparty/guzzlehttp/guzzle/src/Message/FutureResponse.php - line 43: GuzzleHttp\Ring\Future\CompletedFutureValue->then(Object(Closure), NULL, NULL)
/var/www/cloudsub.domain.tld/3rdparty/guzzlehttp/guzzle/src/RequestFsm.php - line 134: GuzzleHttp\Message\FutureResponse proxy(Object(GuzzleHttp\Ring\Future\CompletedFutureArray), Object(Closure))
/var/www/cloudsub.domain.tld/3rdparty/guzzlehttp/guzzle/src/Client.php - line 165: GuzzleHttp\RequestFsm->__invoke(Object(GuzzleHttp\Transaction))
/var/www/cloudsub.domain.tld/3rdparty/guzzlehttp/guzzle/src/Client.php - line 125: GuzzleHttp\Client->send(Object(GuzzleHttp\Message\Request))
/var/www/cloudsub.domain.tld/lib/private/Http/Client/Client.php - line 138: GuzzleHttp\Client->get('https //office....', Array)
/var/www/cloudsub.domain.tld/apps/richdocuments/lib/WOPI/DiscoveryManager.php - line 84: OC\Http\Client\Client->get('https //office....')
/var/www/cloudsub.domain.tld/apps/richdocuments/lib/WOPI/Parser.php - line 41: OCA\Richdocuments\WOPI\DiscoveryManager->get()
/var/www/cloudsub.domain.tld/apps/richdocuments/lib/TokenManager.php - line 148: OCA\Richdocuments\WOPI\Parser->getUrlSrc('application/vnd...')
/var/www/cloudsub.domain.tld/apps/richdocuments/lib/Controller/DocumentController.php - line 168: OCA\Richdocuments\TokenManager->getToken(*** sensitive parameters replaced ***)
[internal function] OCA\Richdocuments\Controller\DocumentController->index('9')
/var/www/cloudsub.domain.tld/lib/private/AppFramework/Http/Dispatcher.php - line 161: call_user_func_array(Array, Array)
/var/www/cloudsub.domain.tld/lib/private/AppFramework/Http/Dispatcher.php - line 91: OC\AppFramework\Http\Dispatcher->executeController(Object(OCA\Richdocuments\Controller\DocumentController), 'index')
/var/www/cloudsub.domain.tld/lib/private/AppFramework/App.php - line 115: OC\AppFramework\Http\Dispatcher->dispatch(Object(OCA\Richdocuments\Controller\DocumentController), 'index')
/var/www/cloudsub.domain.tld/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47: OC\AppFramework\App main('OCA\\Richdocumen...', 'index', Object(OC\AppFramework\DependencyInjection\DIContainer), Array)
[internal function] OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)
/var/www/cloudsub.domain.tld/lib/private/Route/Router.php - line 297: call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)
/var/www/cloudsub.domain.tld/lib/base.php - line 999: OC\Route\Router->match('/apps/richdocum...')
/var/www/cloudsub.domain.tld/index.php - line 42: OC handleRequest()
{main}
The kernel seems to be ready for docker, but I checked with lxc-checkconf, as recommended in an older discussion on: https://forum.odroid.com/viewtopic.php?f=98&t=6638#p52786. It looks fine according my understanding:
user@odroidxu4:~$ lxc-checkconfig
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Warning: newuidmap is not setuid-root
Warning: newgidmap is not setuid-root
Network namespace: enabled
--- Control groups ---
Cgroup: enabled
Cgroup clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup memory controller: enabled
Cgroup cpuset: enabled
--- Misc ---
Veth pair device: enabled
Macvlan: enabled
Vlan: enabled
Bridges: enabled
Advanced netfilter: enabled
CONFIG_NF_NAT_IPV4: enabled
CONFIG_NF_NAT_IPV6: enabled
CONFIG_IP_NF_TARGET_MASQUERADE: enabled
CONFIG_IP6_NF_TARGET_MASQUERADE: enabled
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled
FUSE (for use with lxcfs): enabled
--- Checkpoint/Restore ---
checkpoint restore: missing
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities: enabled
Note : Before booting a new kernel, you can check its configuration
usage : CONFIG=/path/to/config /usr/bin/lxc-checkconfig
The docker log gives a long list with the same line:
sudo docker logs containerID
standard_init_linux.go:190: exec user process caused "exec format error"
I think also my virtual host .conf for the office.domain.tld on apache2 is setup correctly:
<VirtualHost *:443>
ServerName office.domain.tld:443
# SSL configuration, you may want to take the easy route instead and use Lets Encrypt!
SSLCertificateFile /etc/letsencrypt/live/office.domain.tld/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/office.domain.tld/privkey.pem
# Encoded slashes need to be allowed
AllowEncodedSlashes NoDecode
# Container uses a unique non-signed certificate
SSLProxyEngine On
SSLProxyVerify None
SSLProxyCheckPeerCN Off
SSLProxyCheckPeerName Off
# keep the host
ProxyPreserveHost On
# static html, js, images, etc. served from loolwsd
# loleaflet is the client part of LibreOffice Online
ProxyPass /loleaflet https://127.0.0.1:9980/loleaflet retry=0
ProxyPassReverse /loleaflet https://127.0.0.1:9980/loleaflet
# WOPI discovery URL
ProxyPass /hosting/discovery https://127.0.0.1:9980/hosting/discovery retry=0
ProxyPassReverse /hosting/discovery https://127.0.0.1:9980/hosting/discovery
# Main websocket
ProxyPassMatch "/lool/(.*)/ws$" wss://127.0.0.1:9980/lool/$1/ws nocanon
# Admin Console websocket
ProxyPass /lool/adminws wss://127.0.0.1:9980/lool/adminws
# Download as, Fullscreen presentation and Image upload operations
ProxyPass /lool https://127.0.0.1:9980/lool
ProxyPassReverse /lool https://127.0.0.1:9980/lool
</VirtualHost>
I also switched off the firewall, but even without it, collabora is not working.
