Hello everybody,
I have run on my Raspberry Pi nextcloud. The problem is that the view in the “Files” tab is very bad. Why is that? How can I fix the error?
Thank you in advance.
Best regards
Ben
Hello everybody,
Best regards
Ben
In order to help you we need more information about what view error exactly you face. In case show a screenshot.
Thank you. The problem ist solved.
It’s a nice thing to put some hints how you solved it that helps others having the same problem.
