Mi using nexcloud on a Raspberry with openmediavault. Before install Nextcloud I could add files to the NAS from my computer, just using Finder. But now i cant, and all privileges to write and read are gived to my User. I think it is because Nextcloud folder took privilege about OMV could please some one help me!
Thank you
example
longer
example
here
Nextcloud version (eg, 18.0.2):
Operating system and version (eg, Ubuntu 20.04):
PHP version (eg, 7.1):
PASTE HERE
PASTE HERE
PASTE HERE
