I need either get rid of comments or block specific users from commenting.
I wondering if there exisiting option to disable comment section? If not, maybe it can be done by removing some parts of the code?
And the second one, is there a way to allow only particular users to use comments or the other way around - to block some of the users from comment section access?
Thanks,
Dawid
