Hi!
I’ve installed the snappy nextcloud (https://github.com/nextcloud/nextcloud-snap), changed its default HTTP port to 8081 (no interests on HTTPS for now) and configured the reverse proxy with Nginx as the following wiki: https://github.com/nextcloud/nextcloud-snap/wiki/Putting-the-snap-behind-a-reverse-proxy. It works perfectly until I try to configure the custom path ("/nextcloud"), and that’s when I get the “Directory unavailable” message.
On the log file, I got this:
{"reqId":"LIwbZZpG3z32bl5uhCsT","level":4,"time":"2018-09-12T03:38:26+00:00","remoteAddr":"127.0.0.1","user":"gabriel-milan","app":"webdav","method":"PROPFIND","url":"\/nextcloud\/remote.phpp\/webdav\/","message":"Exception: {\"Exception\":\"LogicException\",\"Message\":\"Requested uri (\\\/nextcloud\\\/remote.phpp\\\/webdav\\\/) is out of base uri (\\\/nextcloud\\\/remote.php\\\/webdav\\\/)\",\"Code\":0,\"Trace\":\"#0 \\\/snap\\\/nextcloud\\\/8267\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1296): Sabre\\\\HTTP\\\\Request->getPath()\\n#1 \\\/snap\\\/nextcloud\\\/8267\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(474): Sabre\\\\DAV\\\\Server->checkPreconditions(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#2 \\\/snap\\\/nextcloud\\\/8267\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/snap\\\/nextcloud\\\/8267\\\/htdocs\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(80): Sabre\\\\DAV\\\\Server->exec()\\n#4 \\\/snap\\\/nextcloud\\\/8267\\\/htdocs\\\/remote.php(164): require_once('\\\/snap\\\/nextcloud...')\\n#5 {main}\",\"File\":\"\\\/snap\\\/nextcloud\\\/8267\\\/htdocs\\\/3rdparty\\\/sabre\\\/http\\\/lib\\\/Request.php\",\"Line\":214}","userAgent":"Mozilla\/5.0 (X11; Linux x86_64) AppleWebKit\/537.36 (KHTML, like Gecko) Chrome\/69.0.3497.81 Safari\/537.36","version":"13.0.5.2"}
These are the versions of my stuff:
- Nextcloud version: 13.0.5
- Operating system and version: Debian Stretch
- Apache version: 2.4
- Nginx version: 1.10.3
- PHP version: 7.1
- MySQL version: 5.7
- Redis version: 4.0
And this is my *.conf file for Nginx:
server {
listen 80;
listen [::]:80;
server_name (my_host);
add_header X-Robots-Tag none;
location /nextcloud {
rewrite ^/nextcloud(.*) /$1 break;
proxy_pass_header Server;
proxy_set_header Host $host;
proxy_pass http://127.0.0.1:8081;
Can anyone please help me?
