Hi, new to the forum, thanks for the great tool and community! Now, I am facing a few issues related to larger directories (not individual files) and would greatly appreciate any help, tried understanding/fixing/narrowing this down but no success so far, couldn’t find any posts with exactly the same problem.
The storage usage displayed in the lower left corner goes astray, e.g. showing 68GB even though I am using 11GB only. The command occ files:scan --all will bring this number back to the correct one, but only until I touch anything, at which point the number goes astray again (to the same, wrong number).
some directories do not show their “last updated” and “size” property correctly, even though subfolders inside them do. Notably, this happens on a directory that is >2GB (again, individual files are way smaller than 2GB).
Thanks and cheers
Nextcloud version: 20.0.8
Operating system and version: Debian Buster (arm64 nextcloudpi)
Apache or nginx versionApache/2.4.38 (Debian)
PHP version PHP 7.3.27-1~deb10u1
About your issue there, two things that I need to know for further help:
1) Do you use any cache service, like redis for example. 2) Are you using cron or ajax? 3) The notification of the new released NC 21.0.1 appeared on your application? 4) Are you running php-fpm?
With that info it will be easier to help.
Also, in the log files something strange appears or not?
First of all, did you read the changelog about the 20.0.9 version? Maybe they fixed this bug and we do not have to break our heads to discover it.
But I believe you already checked that, so next step is to see your /etc/php.ini and your /etc/opt/remi/php74/php-fpm.d/www.conf files. If they are in another directory please change it.
I made the workaround of copying all files inside a problematic folder that wouldn’t update its last-edit-timestamp into a new folder. The new folder seems to behave correctly so far. The total space usage counter still goes astray and I did not determine what the actual problem with the file property not getting updated was, so I would not call this a solution.
