example
longer
example
here
I upgraded two separate Nextcloud instances, and on both instances the file app no longer lists all the directories and files in the web UI. Here are the data directories:
Instance 1
root@nextcloud:/usr/share/nginx/nextcloud/data/USERNAME1/files# ls -al
total 24
drwxrwxr-x 6 www-data www-data 4096 Dec 11 15:33 .
drwxrwxr-x 12 www-data www-data 4096 Aug 8 23:10 ..
drwxr-xr-x 5 www-data www-data 4096 Nov 7 2016 Pictures
drwxrwxr-x 3 www-data www-data 4096 Jan 16 2019 'moto G5 Plus'
drwxr-xr-x 19 www-data www-data 4096 Aug 10 2018 ownCloud
drwxr-xr-x 2 www-data www-data 4096 Dec 11 15:33 test
Instance 2
root@iorek:/usr/share/nginx/nextcloud.data/USERNAME1/files# ls -al
total 5488
drwxr-xr-x 5 www-data www-data 4096 Jan 18 2018 .
drwxr-xr-x 8 www-data www-data 4096 May 16 2018 ..
drwxr-xr-x 2 www-data www-data 4096 Jan 18 2018 Documents
-rw-r--r-- 1 www-data www-data 5598648 Jan 18 2018 Nextcloud Manual.pdf
drwxr-xr-x 2 www-data www-data 4096 Jan 18 2018 Photos
drwxr-xr-x 2 www-data www-data 4096 Dec 11 14:08 shared
root@iorek:/usr/share/nginx/nextcloud.data/USERNAME1/files# ls -al Documents/
total 132
drwxr-xr-x 2 www-data www-data 4096 Jan 18 2018 .
drwxr-xr-x 5 www-data www-data 4096 Jan 18 2018 ..
-rw-r--r-- 1 www-data www-data 112672 Jan 18 2018 About.odt
-rw-r--r-- 1 www-data www-data 9720 Jan 18 2018 About.txt
root@iorek:/usr/share/nginx/nextcloud.data/USERNAME1/files# ls -al Photos/
total 3148
root@iorek:/usr/share/nginx/nextcloud.data/USERNAME1/files# ls -al shared/
total 168
drwxr-xr-x 2 www-data www-data 4096 Dec 11 14:08 .
-rw-r--r-- 1 www-data www-data 159924 Dec 11 14:08 passfile.kdbx
And the web UIs:
Instance 1
Instance 2
However, on the Android app the correct directories are listed:
Instance 1
https://i.imgur.com/OU0VJip.png
And strangely, when I make the web UI window narrower, more files appear:
Instance 1
https://i.imgur.com/Hw2penE.png
Instance 2
https: // i . imgur . com/1j2zqky.png
(restricted by 4 link limitation–remove the spaces)
The upgrade paths for the instances were:
Instance #1: 14.0.13 -> 15.0.13 -> 16.0.6 -> 17.0.1
Instance #2: 14.0.14 -> 15.0.13 -> 16.0.6 -> 17.0.1
I remember seeing the file problem somewhere along the way, but I didn’t give too much thought to it because I thought I would be able to fix it with
sudo -u www-data php occ files:scan --all
but running that command didn’t fix the web UI problem.
Nextcloud version (eg, 12.0.2):
Instance 1: 17.0.1
Instance 2: 17.0.1
Operating system and version (eg, Ubuntu 17.04):
Instance 1: Ubuntu 18.04.3 in LXD container
Instance 2: Ubuntu 16.04.6 on a VPS
Instance 1: nginx 1.14.0
Instance 2: nginx 1.15.8
PHP version (eg, 7.1):
Instance 1: 7.2
Instance 2: 7.3
See above
Yes
- upgrade from NC 14 to NC 17
Nothing of note appears in the log when accessing the file app.
Instance 1
'instanceid' => 'REDACTED',
'passwordsalt' => 'REDACTED',
0 => 'owncloud.REDACTED.net',
'datadirectory' => '/usr/share/nginx/nextcloud/data',
'version' => '17.0.1.1',
'dbname' => 'owncloud',
'dbhost' => '192.168.1.100:3306',
'dbuser' => 'nextcloud',
'dbpassword' => 'REDACTED',
'loglevel' => '0',
'forcessl' => true,
'theme' => '',
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'owncloud',
'mail_domain' => 'REDACTED.net',
'enable_previews' => true,
'preview_max_x' => NULL,
'preview_max_y' => NULL,
'preview_max_scale_factor' => 10,
'preview_libreoffice_path' => '/usr/bin/libreoffice',
'preview_office_cl_parameters' => '--headless',
'secret' => 'REDACTED',
'trashbin_retention_obligation' => 'auto',
'overwrite.cli.url' => 'https://owncloud.REDACTED.net',
'trusted_proxies' =>
0 => '10.1.1.10',
1 => '192.168.1.1',
'forwarded_for_headers' =>
0 => 'HTTP_X_FORWARDED_FOR',
'mail_smtphost' => '10.0.0.140',
Instance 2
0 => 'nextcloud.REDACTED.net',
'datadirectory' => '/usr/share/nginx/nextcloud.data',
'overwrite.cli.url' => 'https://nextcloud.REDACTED.net',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:3306',
'loglevel' => 2,
'mail_smtphost' => 'localhost',
Instance 1
10.1.1.10 - - [11/Dec/2019:16:13:28 -0500] "GET /apps/files/ HTTP/1.1" 200 6729 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:28 -0500] "GET /apps/files/ HTTP/1.1" 200 6743 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:28 -0500] "GET /css/core/f317-0f33-server.css?v=5be26923be8f5e6ed7548dc091195c11-9c47f364-5 HTTP/1.1" 200 19224 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:28 -0500] "GET /avatar/USERNAME1/32?v=0 HTTP/1.1" 201 428 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:29 -0500] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 74 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:29 -0500] "GET /apps/gallery/config?extramediatypes=1 HTTP/1.1" 200 102 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:29 -0500] "PROPFIND /remote.php/dav/files/USERNAME1/ HTTP/1.1" 207 4299 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:29 -0500] "GET /index.php/apps/files/ajax/getstoragestats.php?dir=%2F HTTP/1.1" 200 219 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:29 -0500] "GET /apps/recommendations/api/recommendations HTTP/1.1" 200 342 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:29 -0500] "GET /core/preview?fileId=238263&x=32&y=32 HTTP/1.1" 200 4053 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:29 -0500] "GET /core/preview?fileId=238289&x=32&y=32 HTTP/1.1" 200 2747 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:29 -0500] "GET /apps/files/undefined HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
10.1.1.10 - - [11/Dec/2019:16:13:29 -0500] "GET /apps/files/ HTTP/1.1" 200 6728 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
Instance 2
REDACTED - - [11/Dec/2019:16:18:04 -0500] "GET /apps/files/ HTTP/2.0" 499 0 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:04 -0500] "GET /apps/files/ HTTP/2.0" 200 8034 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:04 -0500] "GET /css/core/f317-b63e-server.css?v=a5ac82c56cda553df02ffca8e02fd1be-bcbc1844-3 HTTP/2.0" 499 0 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:04 -0500] "GET /css/files/4039-b63e-merged.css?v=a5ac82c56cda553df02ffca8e02fd1be-40393716-3 HTTP/2.0" 499 0 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:05 -0500] "GET /avatar/USERNAME1/32?v=0 HTTP/2.0" 304 0 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:05 -0500] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 200 74 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:05 -0500] "GET /apps/gallery/config?extramediatypes=1 HTTP/2.0" 200 102 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:05 -0500] "GET /apps/encryption/ajax/getStatus HTTP/2.0" 200 77 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:05 -0500] "GET /apps/systemtags/lastused HTTP/2.0" 200 2 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:05 -0500] "PROPFIND /remote.php/dav/files/USERNAME1/ HTTP/2.0" 207 4829 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:06 -0500] "GET /index.php/apps/files/ajax/getstoragestats.php?dir=%2F HTTP/2.0" 200 216 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:06 -0500] "GET /apps/recommendations/api/recommendations HTTP/2.0" 200 332 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:06 -0500] "GET /core/preview?fileId=191&x=32&y=32 HTTP/2.0" 499 0 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:06 -0500] "GET /core/preview?fileId=196&x=32&y=32 HTTP/2.0" 499 0 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
REDACTED - - [11/Dec/2019:16:18:06 -0500] "GET /core/preview?fileId=202&x=32&y=32 HTTP/2.0" 499 0 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0"
