there are 2 apps in the appstore:
- Direct Menu 0.8 https://apps.owncloud.com/content/show.php?content=169148
- Direct Menu 1 https://apps.owncloud.com/content/show.php?content=174705
The first one works well. Don’t know what the 2nd one does.
Trying to enable the 2nd one in nextcloud shows
“App can’t be installed because the version in info.xml/version is not the same as the version reported from the app store”
Shouldn’t the 2nd one be renamed?
https://apps.owncloud.com/content/show.php?content=169148&forumpage=3
Ciao,
Joachim
