joho68
September 4, 2020, 7:43am
1
Does anyone know the difference between these two properties (WebDAV) in Nextcloud?
{http://owncloud.org/ns}id
The fileid namespaced by the instance id, globally unique
{http://owncloud.org/ns}fileid
The unique id for the file within the instance
I guess what I’m asking is “globally unique” vs “unique for the file within the instance”?
so in your config/config.php you have an “instanceid”, e.g. ocrb3ervk02w
in my def enviroment.
The fileid is the number in the oc_filecache
table. So the file that has fileid = 12345
there will have:
set to 00012345ocrb3ervk02w
(fileid with padding zeros to be at least 8 numberes)
set to 12345
joho68
September 4, 2020, 1:03pm
3
Thank you for a clear answer! So, assuming I have some way to identify the instance, either by “instanceid”, or by other means, the fileid is sufficient to uniquely identify a file for a Nextcloud instance/site/installation?
yes, fileid is an autoincrement column in the database. after deleting a file it will not be reused for the next new one.
