Error no app in context Sabre\HTTP\ClientHttpException: Forbidden
/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Client.php - line 231: Sabre\HTTP\Client->send(Object(Sabre\HTTP\Request))
/var/www/html/nextcloud/lib/private/Files/Storage/DAV.php - line 268: Sabre\DAV\Client->propFind(‘https //webdav…’, Array)
/var/www/html/nextcloud/lib/private/Files/Storage/DAV.php - line 323: OC\Files\Storage\DAV->propfind(‘users/.nomedia’)
/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php - line 220: OC\Files\Storage\DAV->file_exists(‘users/.nomedia’)
/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php - line 220: OC\Files\Storage\Wrapper\Wrapper->file_exists(‘users/.nomedia’)
/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php - line 241: OC\Files\Storage\Wrapper\Wrapper->file_exists(‘users/.nomedia’)
/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php - line 220: OC\Files\Storage\Wrapper\Availability->file_exists(‘users/.nomedia’)
/var/www/html/nextcloud/lib/private/Files/View.php - line 1296: OC\Files\Storage\Wrapper\Wrapper->file_exists(‘users/.nomedia’)
/var/www/html/nextcloud/lib/private/Files/View.php - line 1342: OC\Files\View->getCacheEntry(Object(OCA\FilesAutomatedTagging\StorageWrapper), ‘users/.nomedia’, ‘/admin/files/Hi…’)
/var/www/html/nextcloud/lib/private/Files/Node/Root.php - line 196: OC\Files\View->getFileInfo(’/admin/files/Hi…’)
/var/www/html/nextcloud/lib/private/Files/Node/Folder.php - line 122: OC\Files\Node\Root->get(’/admin/files/Hi…’)
/var/www/html/nextcloud/lib/private/Files/Node/Folder.php - line 131: OC\Files\Node\Folder->get(’.nomedia’)
/var/www/html/nextcloud/apps/gallery/service/filesservice.php - line 145: OC\Files\Node\Folder->nodeExists(’.nomedia’)
/var/www/html/nextcloud/apps/gallery/service/searchmediaservice.php - line 67: OCA\Gallery\Service\FilesService->getAllowedSubFolder(Object(OC\Files\Node\Folder), ‘dir’)
/var/www/html/nextcloud/apps/gallery/service/searchmediaservice.php - line 131: OCA\Gallery\Service\SearchMediaService->searchFolder(Object(OC\Files\Node\Folder), 1)
/var/www/html/nextcloud/apps/gallery/service/searchmediaservice.php - line 73: OCA\Gallery\Service\SearchMediaService->searchSubFolders(Array, 1, 1)
/var/www/html/nextcloud/apps/gallery/service/searchmediaservice.php - line 44: OCA\Gallery\Service\SearchMediaService->searchFolder(Object(OC\Files\Node\Folder))
/var/www/html/nextcloud/apps/gallery/controller/files.php - line 76: OCA\Gallery\Service\SearchMediaService->getMediaFiles(Object(OC\Files\Node\Folder), Array, Array)
/var/www/html/nextcloud/apps/gallery/controller/filescontroller.php - line 98: OCA\Gallery\Controller\FilesController->getFilesAndAlbums(’’, Array, ‘’, Array)
[internal function] OCA\Gallery\Controller\FilesController->getList(’’, ‘’, ‘’, ‘image/png;image…’)
/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 160: call_user_func_array(Array, Array)
/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 90: OC\AppFramework\Http\Dispatcher->executeController(Object(OCA\Gallery\Controller\FilesController), ‘getList’)
/var/www/html/nextcloud/lib/private/AppFramework/App.php - line 114: OC\AppFramework\Http\Dispatcher->dispatch(Object(OCA\Gallery\Controller\FilesController), ‘getList’)
/var/www/html/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47: OC\AppFramework\App main(‘FilesController’, ‘getList’, Object(OC\AppFramework\DependencyInjection\DIContainer), Array)
[internal function] OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)
/var/www/html/nextcloud/lib/private/Route/Router.php - line 299: call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)
/var/www/html/nextcloud/lib/base.php - line 1010: OC\Route\Router->match(’/apps/gallery/f…’)
/var/www/html/nextcloud/index.php - line 40: OC handleRequest()
{main}
Error gallery OCP\Files\StorageNotAvailableException: Sabre\HTTP\ClientHttpException: Forbidden
/var/www/html/nextcloud/lib/private/Files/Storage/DAV.php - line 329: OC\Files\Storage\DAV->convertException(Object(Sabre\HTTP\ClientHttpException), ‘users/.nomedia’)
{main}
