Nextcloud version (eg, 20.0.5): 2.6.5-20200713.144448.adada8b2e-1.0~xenial1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 16.04 LTS
Apache or nginx version (eg, Apache 2.4.25): Not the Server
PHP version (eg, 7.4): Not the server
Is this the first time you’ve seen this error? (Y/N): I have had this issue, completely disabling NextCloud on this machine, for two or three weeks.
Unfortunately, I don’t have a solution for your specific problem, but I would like to mention two things…
The standard LTS support of Ubuntu 16.04 ended in April 2021. If you don’t have an extended support contract with Canonical, you should consider upgrading to 18.04 at least.
If you use the Nextcloud client from the PPA, it is possible that certain dependencies are missing or too old on your system…
NOTE for Xenial users: because Xenial contains some outdated libraries, such as Qt5.5 and libssl 1.0, which are no longer fully supported by the Nextcloud client, the Xenial build in this repository is on a strictly best-effort basis only. It means that some functionality may not work properly or at all. It is also possible that Xenial support in this PPA will be discontinued altogether at some point in the future.
Well, I was successful installing the AppImage, and it started despite showing the same error. However, once it logged in to the Server, it said: “Danger Will Robinson!” My last upgrade of the server took it to a version 15 installation, and it doesn’t seem to want to go beyond that.
So, I will continue to leave this machine broken, and work on upgrading the Server.
I think that what I will do is do a “clean” install ( rename the root directory and do a fresh install of the current version of NC ) and then move the data back into the directory tree.
Once I’ve done that, I can work on this machine ( the client ) and upgrade it, both OS and NC Client.
