Hi
This is not the first time I have this issue but I can’t find any permanent solution and/or the cause. Sometimes I install a NC desktop client in a Mac, it loads perfectly, configure the account and the first sync works ok. After that I reboot and the client does not load anymore I’ve been able to fix that in the past installing an older client version and not upgraging it.
The Mac I’ve tried to configure today is an M2, latests MacOS version, latest NC desktop client (3.16.5) , it installs but the wizard to configure the account does not start and the client does not load in any way. I’ve removed the client and installed the 3.10.0 version, it loaded right, configure the account, first sync ok but after the reboot the client does not load anymore. I’ve tried to reinstall the 3.15, 3.16…no way to get a client up and running.
Any idea?
