I think that my setup affected by the same issue.
Short description:
- Files are not synced
- Settings Dialogue and main dialogue in client can not be opened (from context menu)
- Bruteforce Table is empty (SELECT * FROM kuumaur_nextcloud.oc_bruteforce_attempts;)
Is there any solution? Or any Ideas how to narrow down the issue?
Until now, it is only 1 client impacted. The others are running well.
Fast-forward I did these steps:
- reinstalled Nextcloud-Client multiple times
- reinstalled Manjaro/KDE, Client is working for at least some reboots, after that it is stuck again
- reinstalled Manjaro with XFCE Edition, Client is working for at least some reboots, after that it is stuck again
- bruteforce disabled/allowed
Some details regarding the setup:
Client:
Nextcloud version 3.4.1git
Git revision fa32c100148925092c9a320e6f8e2e0130b9cb6a
Using Qt 5.15.2, built against Qt 5.15.2
Using Qt platform plugin âxcbâ
Using âOpenSSL 1.1.1m 14 Dec 2021â
Running on Manjaro Linux, x86_64
XFCE Desktop
Server:
Debian 11 as LXC Container in Proxmox v7.0
Kernel 5.13.19-2pve
mysql Ver 15.1 Distrib 10.5.12-MariaDB, for debian-linux-gnu (x86_64) using EditLine wrapper
root@nextcloud-prod:/var/www/html# sudo -u www-data ./occ status
- installed: true
- version: 23.0.0.10
- versionstring: 23.0.0
- edition:
- maintenance: false
- needsDbUpgrade: false
- productname: Nextcloud
- extendedSupport: false
root@nextcloud-prod:/var/www/html# sudo -u www-data ./occ app:list
- activity: 2.15.0
- admin_audit: 1.13.0
- audioplayer: 3.2.4
- bruteforcesettings: 2.3.0
- calendar: 3.0.4
- camerarawpreviews: 0.7.15
- cloud_federation_api: 1.6.0
- comments: 1.13.0
- contacts: 4.0.7
- contactsinteraction: 1.4.0
- dav: 1.21.0
- deck: 1.6.0
- dicomviewer: 1.2.3
- drawio: 1.0.2
- duplicatefinder: 0.0.13
- event_update_notification: 1.4.0
- extract: 1.3.3
- federatedfilesharing: 1.13.0
- files: 1.18.0
- files_external: 1.15.0
- files_markdown: 2.3.5
- files_pdfviewer: 2.4.0
- files_rightclick: 1.2.0
- files_sharing: 1.15.0
- files_trashbin: 1.13.0
- files_versions: 1.16.0
- files_videoplayer: 1.12.0
- fileslibreofficeedit: 1.0.2
- firstrunwizard: 2.12.0
- groupfolders: 11.1.0
- keeweb: 0.6.8
- login_notes: 1.0.1
- logreader: 2.8.0
- lookup_server_connector: 1.11.0
- mail: 1.11.5
- notes: 4.2.0
- notifications: 2.11.1
- oauth2: 1.11.0
- password_policy: 1.13.0
- photos: 1.5.0
- previewgenerator: 3.4.1
- privacy: 1.7.0
- provisioning_api: 1.13.0
- richdocuments: 5.0.1
- richdocumentscode: 21.11.6
- serverinfo: 1.13.0
- settings: 1.5.0
- sharebymail: 1.13.0
- systemtags: 1.13.0
- tasks: 0.14.2
- text: 3.4.0
- twofactor_backupcodes: 1.12.0
- twofactor_email: 2.1.1
- twofactor_nextcloud_notification: 3.3.1
- twofactor_totp: 6.2.0
- twofactor_u2f: 6.3.0
- twofactor_webauthn: 0.2.14
- updatenotification: 1.13.0
- viewer: 1.7.0
- welcome: 1.0.1
- wopi: 3.5.10
- workflowengine: 2.5.0
- accessibility
- bookmarks
- circles
- collectives
- dashboard
- encryption
- federation
- forms
- geoblocker
- metadata
- nextcloud_announcements
- ransomware_protection
- recommendations
- registration
- support
- survey_client
- theming
- user_ldap
- user_status
- weather_status
nextcloud.log:
{âreqIdâ:âGLN7gLlyhMSZF8RAQDPlâ,âlevelâ:4,âtimeâ:âJanuary 10, 2022 13:05:31â,âremoteAddrâ:â192.168.200.211â,âuserâ:âuweâ,âappâ:âwebdavâ,âmethodâ:âPOSTâ,âurlâ:"/remote.php/dav/bulk",âmessageâ:âUnknown error while seeking contentâ,âuserAgentâ:âMozilla/5.0 (Linux) mirall/3.4.1git (Nextcloud, manjaro-5.15.12-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)â,âversionâ:â23.0.0.10â,âexceptionâ:{âExceptionâ:âSabre\DAV\Exceptionâ,âMessageâ:âUnknown error while seeking contentâ,âCodeâ:500,âTraceâ:[{âfileâ:"/var/www/html/apps/dav/lib/BulkUpload/MultipartRequestParser.php",âlineâ:129,âfunctionâ:âisAtâ,âclassâ:âOCA\DAV\BulkUpload\MultipartRequestParserâ,âtypeâ:"->"},{âfileâ:"/var/www/html/apps/dav/lib/BulkUpload/BulkUploadPlugin.php",âlineâ:69,âfunctionâ:âisAtLastBoundaryâ,âclassâ:âOCA\DAV\BulkUpload\MultipartRequestParserâ,âtypeâ:"->"},{âfileâ:"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",âlineâ:89,âfunctionâ:âhttpPostâ,âclassâ:âOCA\DAV\BulkUpload\BulkUploadPluginâ,âtypeâ:"->"},{âfileâ:"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php",âlineâ:472,âfunctionâ:âemitâ,âclassâ:âSabre\DAV\Serverâ,âtypeâ:"->"},{âfileâ:"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php",âlineâ:253,âfunctionâ:âinvokeMethodâ,âclassâ:âSabre\DAV\Serverâ,âtypeâ:"->"},{âfileâ:"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php",âlineâ:321,âfunctionâ:âstartâ,âclassâ:âSabre\DAV\Serverâ,âtypeâ:"->"},{âfileâ:"/var/www/html/apps/dav/lib/Server.php",âlineâ:339,âfunctionâ:âexecâ,âclassâ:âSabre\DAV\Serverâ,âtypeâ:"->"},{âfileâ:"/var/www/html/apps/dav/appinfo/v2/remote.php",âlineâ:35,âfunctionâ:âexecâ,âclassâ:âOCA\DAV\Serverâ,âtypeâ:"->"},{âfileâ:"/var/www/html/remote.php",âlineâ:166,âargsâ:["/var/www/html/apps/dav/appinfo/v2/remote.php"],âfunctionâ:ârequire_onceâ}],âFileâ:"/var/www/html/apps/dav/lib/BulkUpload/MultipartRequestParser.php",âLineâ:111,âCustomMessageâ:"â"}}
