Hi together,
Nextcloud version (eg, 20.0.5): '21.0.0.18
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): nginx/1.18.0 (Ubuntu)
PHP version (eg, 7.4): 7.4
Setup:
VPS ssh forward proxy to homeserver, on homeserver using nginx to handel TLS and nextcloud access etc. Using self-signed certs.
The service is accessible with the mobile clients and also syncable, but the Nextcloud desktop sync client on Ubuntu is throwing errors and I am unable to sync/upload.
I am able to connect to the nextcloud instance but I am unable to sync to it:
Judging from the logs, I would assume especially the last two entries are relevant, but I do not know what to do.
Also it tells me that appinfo/app.php is deprecated
, not sure why.
The desktop client is the one available in snap store, but I also tried unsuccessfully the provided AppImage.
Any help is appreciated.
https://pastebin.com/8fMskE1W
'passwordsalt' => 'QWwiJCFuAc1RwJJAszFY8nYmlOOfGt',
'secret' => 'Sa3Sr4gNJ3ta123Idq9VEgtpsWD3nwEV7BEdIIUSzqfBYrfr',
0 => 'localhost',
1 => 'XXXXXXXXXX',
'version' => '21.0.0.18',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'XXXXXXXXXXX',
'dbpassword' => 'XXXXXXXXXXX',
'instanceid' => 'XXXXXXXXX',
"log_type" => "syslog",
"logfile" => "",
"loglevel" => 0,
The output of your Apache/nginx/system log in /var/log/nginx/{access|error}.log
127.0.0.1 - me [24/Mar/2021:14:38:03 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications?format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Linux) mirall/2.6.4-1 (Nextcloud)"
