The Nextcloud desktop team just made RC1 of the new major version available! This release comes with a lot of changes to the sync engine, many UI fixes, improvements to end-to-end encryption, a virtual file system, a new installation wizard and more. So, it needs some real testing!
You can find a list of the main included commits on github, where you can also download the builds for mac , linux and windows
We’d like to ask for help with testing these in particular:
if you had regular sync issues, try this RC and tell us if they are resolved or not!
if you had problems with the conflict handling dialog, they should be fixed. Let us know!
If you tried end-to-end encryptions and experienced problems, they should be resolved - let us know!
try the virtual file system, especially on Windows
we’d love to hear what you think of the new installation wizard!
You can put your below, and ask questions, but real bug reports are best filed on github (be sure to check for duplicates please)!
CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28 (find_package):
Could not find a package configuration file provided by “Qt5QuickControls2”
with any of the following names:
Does this release run natively on Apple ARM machines? The NextCloud Desktop Client is the last remaining app I use which is still running in emulation mode.
