example
longer
example
here
Nextcloud version (eg, 29.0.5): 29.0.4
Operating system and version (eg, Ubuntu 24.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.52
PHP version (eg, 8.3): 8.1
My color design keeps getting reverted by my background only the buttons keep the color but not the Header bar for example. (It only works for a very brief moment before getting reset)
- set a color design
- color theme gets reset by background
PASTE HERE
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => '',
'version' => '29.0.4.1',
'overwrite.cli.url' => '',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => '',
'default_language' => 'de',
'default_locale' => 'de_DE',
'remember_login_cookie_lifetime' => 25200,
'twofactor_enforced' => 'false',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'timeout' => 0.0,
'theme' => '',
'loglevel' => 2,
PASTE HERE
no errors
