I am trying to implement a solution with:
1 Load Balancer
2 x Nextcloud application servers
1 x External PostgreSQL server (1 master / 1 slave). Already existing and used by other applications.
1 x Redis Server
1 x NFS server as a common drive for data, exposed to both Nexcloud application servers.
I have some doubts and I have tried to find information throughout the help posts, but I have not been able to solve all the doubts.
Can I first create a VM with Nextcloud and, once the installation and configuration is complete, clone that VM to create the second server? (Obviously with a different name and network configuration). ?
If I make any changes to one of the 2 servers. For example, installation of a new app. Is it necessary to perform the manual installation of that app on the second server, or is the change made in the database and the second server “finds out” and updates its configuration automatically?
Lastly, regarding the Redis server. In the tests I have been doing (1 single server, with local database, I have installed Redis on the server itself. If I choose the solution indicated in the beginning (1 load balancer, 2 servers, external database … .) Is it necessary to create a dedicated Redis server ?, or, Is it enough to install Redis on each of the 2 servers ?.
Thank you very much in advance.
