I have a nextcloud with many users. I do not want them to see each others e-mail-adresses. Thatswhy I want to set the e-mail-adress to “private” in the personal settings of every user by default. I do not want to disable the autocomplete of the usernames when sharing items in the global settings because I think it is a useful tool when it comes to usernames.
Is it possible to set the e-mail-adress to private in the default user settings? Is there any trick like a snippet of code which sets the option when registering a new user?
Then you have to modify the source code to remove email addresses from the dropdown menu. I’m assuming that’s what you’re talking about. I don’t think it’s more then one or two lines of code.
