Nextcloud version: 15.0.7
Operating system and version: CentOS 6
Apache or nginx version: don’t know (shared hosting)
PHP version: 7.2.19
When mounting external storage via WebDAV, the data is encrypted, but the decryption does not work.
When I mount the external storage via SFTP decryption works fine.Dieser Text wird versteckt
Is this the first time you’ve seen this error?: Y
- Enable server-side encryption and allow users to mount external storage
- Mount external storage (in my case strato HiDrive) via WebDAV
- Add some files via Nextcloud web interface or local nextcloud client
- Try to open the files via nextcloud web interface.
- “Missing signature” error occurs
https://sebsauvage.net/paste/?f8e99eabe770b24b#rLYMg/vVCxBZ35oI2a2OSwSPi5zEoMoWRrjGCcXm2Lk=
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => '',
'datadirectory' => '/home/[USER]/nextcloud_data',
'overwrite.cli.url' => '',
'overwritewebroot' => '/',
'version' => '15.0.7.0',
'dbname' => '',
'dbhost' => 'localhost',
'dbuser' => '',
'dbpassword' => '',
'mail_smtpmode' => 'sendmail',
'mail_domain' => '',
'loglevel' => 0,
'theme' => '',
'redis' =>
'host' => '/home/[USER]/.redis/sock',
'port' => 0,
'timeout' => 0,
'trashbin_retention_obligation' => '0,0',
'twofactor_enforced' => 'false',
'skeletondirectory' => '',
don't have that
