example
longer
example
here
Nextcloud version (eg, 12.0.2): 14.0.4.2
Operating system and version (eg, Ubuntu 17.04): Alpine Linux 3.8
Apache or nginx version (eg, Apache 2.4.25): 1.14.1
PHP version (eg, 7.1): 7.2.12
Failing to connect external storage using WebDAV.
The external storage provider is 1und1.
I can mount this WebDAV storage w/o issues in Windows as a network share.
Is this the first time you’ve seen this error? (Y/N): y
- Settings
- Admin
- External Storage
- Select type “WebDAV”
empty
empty
Question:
How can I debug this issue in order to identify the root cause?
