how can I continue - or see completion of - a started DB Conversion (from SQLite to MariaDB)?
The conversion was started successfully, but in the middle, the SSH pipe broke.
I don’t see any log entry (where) and can’t restart the same command as the DB already exists.
Command used was:
sudo -u apache /usr/bin/php occ db:convert-type --all-apps mysql nextclouduser 127.0.0.1 nextcloud
Output until the end of the SSH session:
Creating schema in new database
The following tables will not be converted:
oc_privatedata
Continue with the conversion (y/n)? [n] y
oc_accounts
2/2 [============================] 100%oc_activity
chunked query, 28 chunks
27170/27170 [============================] 100%oc_activity_mq
0 [>---------------------------]oc_addressbookchanges
22/22 [============================] 100%oc_addressbooks
2/2 [============================] 100%oc_appconfig
165/165 [============================] 100%oc_authtoken
101/101 [============================] 100%oc_bruteforce_attempts
378/378 [============================] 100%oc_calendar_invitations
0 [>---------------------------]oc_calendar_reminders
0 [>---------------------------]oc_calendar_resources
0 [>---------------------------]oc_calendar_resources_md
0 [>---------------------------]oc_calendar_rooms
0 [>---------------------------]oc_calendar_rooms_md
0 [>---------------------------]oc_calendarchanges
0 [>---------------------------]oc_calendarobjects
0 [>---------------------------]oc_calendarobjects_props
0 [>---------------------------]oc_calendars
2/2 [============================] 100%oc_calendarsubscriptions
0 [>---------------------------]oc_cards
2/2 [============================] 100%oc_cards_properties
8/8 [============================] 100%oc_collres_accesscache
0 [>---------------------------]oc_collres_collections
0 [>---------------------------]oc_collres_resources
0 [>---------------------------]oc_comments
0 [>---------------------------]oc_comments_read_markers
0 [>---------------------------]oc_credentials
0 [>---------------------------]oc_dav_cal_proxy
0 [>---------------------------]oc_dav_shares
0 [>---------------------------]oc_direct_edit
0 [>---------------------------]oc_directlink
0 [>---------------------------]oc_federated_reshares
0 [>---------------------------]oc_file_locks
chunked query, 125 chunks
124173/124173 [============================] 100%oc_filecache
chunked query, 771 chunks
48500/770656 [=>--------------------------] 6%client_loop: send disconnect: Broken pipe
This is where it stopped.
What can I do?
Thanks upfront!
Nextcloud version: 19.0.2.2
Operating system and version: CentOS 7.8
Apache or nginx version: Apache/2.4.6 (CentOS)
PHP version: PHP 7.4.9
Is this the first time you’ve seen this error? (Y/N) : Y
- Upgrade to 19.0.2.2
- Start db:convert-type command as above
- SSH pipe breaks while waiting for result
