I have a problem related to brazil time zones.
Actually, repeating events created with Paris time zone, for example, are being showed with the wrong time in sao paulo time zone from 3rd november.
This is certainly due to the change made by the government and the end of daylight saving time in Brazil.
Anyone could help me with that?
Best regards,
Waldir
Most likely you have to update the timezone database on your server as described here. The following keywords might help you asking aunt G. for further information: “linux update timezone database”
Thank you very much!
I send the info to my host and they will try to fix that (they said me before that was my problem…).
If everything is ok, i come back here to say and close the ticket.
I have the same problem but am on Debian
sudo dpkg-reconfigure tzdata
Much and good luck,
ernolf
