I found this in the latest beta of DAVx⁵ (https://play.google.com/store/apps/details?id=at.bitfire.davdroid)
- implement Nextcloud login flow (can be called from Nextcloud app)
How can I use this?
Thanks!
How can I use this?
Thanks!
take a look in the NC App, there should be in the menue something.
Thanks for your reply.
Do you know where the setting is? Can’t find it…
NC App, hamburger, preferences, Calendar and contacts sync.
Or similar, my App is not english, sorry.
The new intent for DAVx⁵ has to be documented yet. But then the NC app can be updated so that it calls DAVx⁵ with the login flow, so that you can use 2FA and such things easily.
So, I can’t use it right now?
Not really; except you call it yourself, for instance with adb, see https://forums.bitfire.at/post/12082
As soon as https://github.com/nextcloud/android/pull/4716 has been merged and released. This might happen with the next feature release (3.9.0) or the one after that.
