I have a server with Nextcloud 12.0.3
when I try to mount any directory via davfs2 on a fedora 27 client , the mount is ok but is always read-only.
I follow the instructions : https://docs.nextcloud.com/server/12/user_manual/files/access_webdav.html?highlight=sync#creating-webdav-mounts-on-the-linux-command-line
/etc/fstab contains “… davfs user,rw,auto 0 0…”
I set use_lock 0 without success
When I mount this directory on the same machine with the file manager nemo, it is ok : the directory is read-write
When I mount this directory on a windows 10 machine , via https , it is ok . read/write flawlessly
Any hint ?
is there another way to mount directory via webdav ?
thank you
Server :
Nextcloud 12.0.3
on a Centos 7.4
httpd-2.4.6-67
php-5.6.32
Client :
fedora 27
davfs2 1.5.4-6
