Hello, I am trying to access DAVdroid via Disroot mobile. However, I am getting an error stating DAVdroid cannot find CalDAV/CardDAV service.
I’m not sure what I’m doing wrong here.
If this is the wrong category to post this I apologize.
--- BEGIN DEBUG INFO ---
LOGS:
2018-09-03 00:10:49 45357 [ui.setup.DavResourceFinder] Finding initial carddav service configuration
2018-09-03 00:10:49 45357 [ui.setup.DavResourceFinder] Checking user-given URL: https://cloud.disroot.org/remote.php/dav
2018-09-03 00:10:49 45357 [HttpClient] --> PROPFIND https://cloud.disroot.org/remote.php/dav
2018-09-03 00:10:49 45357 [HttpClient] Content-Type: application/xml; charset=utf-8
2018-09-03 00:10:49 45357 [HttpClient] Content-Length: 290
2018-09-03 00:10:49 45357 [HttpClient] Depth: 0
2018-09-03 00:10:49 45357 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?><propfind xmlns="DAV:" xmlns:CAL="urn:ietf:params:xml:ns:caldav" xmlns:CARD="urn:ietf:params:xml:ns:carddav"><prop><resourcetype /><displayname /><CARD:addressbook-description /><CARD:addressbook-home-set /><current-user-principal /></prop></propfind>
2018-09-03 00:10:49 45357 [HttpClient] --> END PROPFIND (290-byte body)
2018-09-03 00:10:50 45357 [HttpClient] <-- 404 Not Found https://cloud.disroot.org/remote.php/dav (975ms)
2018-09-03 00:10:50 45357 [HttpClient] Server: nginx
2018-09-03 00:10:50 45357 [HttpClient] Date: Mon, 03 Sep 2018 07:10:49 GMT
2018-09-03 00:10:50 45357 [HttpClient] Content-Type: text/html
2018-09-03 00:10:50 45357 [HttpClient] Transfer-Encoding: chunked
2018-09-03 00:10:50 45357 [HttpClient] Connection: keep-alive
2018-09-03 00:10:50 45357 [HttpClient] Keep-Alive: timeout=30
2018-09-03 00:10:50 45357 [HttpClient] Vary: Accept-Encoding
2018-09-03 00:10:50 45357 [HttpClient] <html>
<head><title>404 Not Found</title></head>
<body bgcolor="white">
<center><h1>404 Not Found</h1></center>
<hr><center>nginx</center>
</body>
</html>
2018-09-03 00:10:50 45357 [HttpClient] <-- END HTTP (162-byte body)
2018-09-03 00:10:50 45357 [ui.setup.DavResourceFinder] PROPFIND/OPTIONS on user-given URL failed
EXCEPTION at.bitfire.dav4android.exception.NotFoundException: HTTP 404 Not Found
at at.bitfire.dav4android.DavResource.checkStatus(DavResource.kt:275)
at at.bitfire.dav4android.DavResource.checkStatus(DavResource.kt:259)
at at.bitfire.dav4android.DavResource.processMultiStatus(DavResource.kt:351)
at at.bitfire.dav4android.DavResource.propfind(DavResource.kt:246)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.checkUserGivenURL(DavResourceFinder.kt:177)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:112)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:77)
at at.bitfire.davdroid.ui.setup.DetectConfigurationFragment$ServerConfigurationLoader.loadInBackground(DetectConfigurationFragment.kt:136)
at at.bitfire.davdroid.ui.setup.DetectConfigurationFragment$ServerConfigurationLoader.loadInBackground(DetectConfigurationFragment.kt:120)
at android.support.v4.content.AsyncTaskLoader.onLoadInBackground(AsyncTaskLoader.java:306)
at android.support.v4.content.AsyncTaskLoader$LoadTask.doInBackground(AsyncTaskLoader.java:59)
at android.support.v4.content.AsyncTaskLoader$LoadTask.doInBackground(AsyncTaskLoader.java:47)
at android.support.v4.content.ModernAsyncTask$2.call(ModernAsyncTask.java:138)
at java.util.concurrent.FutureTask.run(FutureTask.java:237)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
at java.lang.Thread.run(Thread.java:761)
2018-09-03 00:10:50 45357 [HttpClient] --> PROPFIND https://cloud.disroot.org/.well-known/carddav
2018-09-03 00:10:50 45357 [HttpClient] Content-Type: application/xml; charset=utf-8
2018-09-03 00:10:50 45357 [HttpClient] Content-Length: 198
2018-09-03 00:10:50 45357 [HttpClient] Depth: 0
2018-09-03 00:10:50 45357 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?><propfind xmlns="DAV:" xmlns:CAL="urn:ietf:params:xml:ns:caldav" xmlns:CARD="urn:ietf:params:xml:ns:carddav"><prop><current-user-principal /></prop></propfind>
2018-09-03 00:10:50 45357 [HttpClient] --> END PROPFIND (198-byte body)
2018-09-03 00:10:50 45357 [HttpClient] <-- 403 Forbidden https://cloud.disroot.org/.well-known/carddav (174ms)
<head><title>403 Forbidden</title></head>
<center><h1>403 Forbidden</h1></center>
</body>
</html>
2018-09-03 00:10:50 45357 [ui.setup.DavResourceFinder] Well-known URL detection failed
EXCEPTION at.bitfire.dav4android.exception.HttpException: HTTP 403 Forbidden
at at.bitfire.dav4android.DavResource.checkStatus(DavResource.kt:283)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.getCurrentUserPrincipal(DavResourceFinder.kt:382)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:116)
2018-09-03 00:10:50 45357 [ui.setup.DavResourceFinder] No principal found at user-given URL, trying to discover
2018-09-03 00:10:50 45357 [ui.setup.DavResourceFinder] Looking up SRV records for _carddavs._tcp.cloud.disroot.org
2018-09-03 00:10:50 45357 [ui.setup.DavResourceFinder] Didn't find carddav service, trying at https://cloud.disroot.org:443
2018-09-03 00:10:50 45357 [ui.setup.DavResourceFinder] Trying to determine principal from initial context path=https://cloud.disroot.org/.well-known/carddav
2018-09-03 00:10:50 45357 [HttpClient] <-- 403 Forbidden https://cloud.disroot.org/.well-known/carddav (196ms)
</body>
</html>
2018-09-03 00:10:50 45357 [ui.setup.DavResourceFinder] No resource found
at at.bitfire.davdroid.ui.setup.DavResourceFinder.discoverPrincipalUrl(DavResourceFinder.kt:362)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:135)
2018-09-03 00:10:50 45357 [HttpClient] <-- 405 Not Allowed https://cloud.disroot.org/ (179ms)
2018-09-03 00:10:50 45357 [HttpClient] Date: Mon, 03 Sep 2018 07:10:50 GMT
2018-09-03 00:10:50 45357 [HttpClient] Content-Length: 166
<head><title>405 Not Allowed</title></head>
<center><h1>405 Not Allowed</h1></center>
</body>
</html>
2018-09-03 00:10:50 45357 [HttpClient] <-- END HTTP (166-byte body)
EXCEPTION at.bitfire.dav4android.exception.HttpException: HTTP 405 Not Allowed
2018-09-03 00:10:50 45357 [ui.setup.DavResourceFinder] Finding initial caldav service configuration
2018-09-03 00:10:50 45357 [ui.setup.DavResourceFinder] Checking user-given URL: https://cloud.disroot.org/remote.php/dav
2018-09-03 00:10:50 45357 [HttpClient] --> PROPFIND https://cloud.disroot.org/remote.php/dav
2018-09-03 00:10:50 45357 [HttpClient] Content-Length: 435
2018-09-03 00:10:50 45357 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?><propfind xmlns="DAV:" xmlns:CAL="urn:ietf:params:xml:ns:caldav" xmlns:CARD="urn:ietf:params:xml:ns:carddav"><prop><resourcetype /><displayname /><n0:calendar-color xmlns:n0="http://apple.com/ns/ical/" /><CAL:calendar-description /><CAL:calendar-timezone /><current-user-privilege-set /><CAL:supported-calendar-component-set /><CAL:calendar-home-set /><current-user-principal /></prop></propfind>
2018-09-03 00:10:50 45357 [HttpClient] --> END PROPFIND (435-byte body)
2018-09-03 00:10:51 45357 [HttpClient] <-- 404 Not Found https://cloud.disroot.org/remote.php/dav (173ms)
2018-09-03 00:10:51 45357 [HttpClient] Server: nginx
2018-09-03 00:10:51 45357 [HttpClient] Date: Mon, 03 Sep 2018 07:10:50 GMT
2018-09-03 00:10:51 45357 [HttpClient] Content-Type: text/html
2018-09-03 00:10:51 45357 [HttpClient] Transfer-Encoding: chunked
2018-09-03 00:10:51 45357 [HttpClient] Connection: keep-alive
2018-09-03 00:10:51 45357 [HttpClient] Keep-Alive: timeout=30
2018-09-03 00:10:51 45357 [HttpClient] Vary: Accept-Encoding
2018-09-03 00:10:51 45357 [HttpClient] <html>
</body>
</html>
2018-09-03 00:10:51 45357 [HttpClient] <-- END HTTP (162-byte body)
2018-09-03 00:10:51 45357 [ui.setup.DavResourceFinder] PROPFIND/OPTIONS on user-given URL failed
at at.bitfire.davdroid.ui.setup.DavResourceFinder.checkUserGivenURL(DavResourceFinder.kt:186)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:78)
2018-09-03 00:10:51 45357 [HttpClient] --> PROPFIND https://cloud.disroot.org/.well-known/caldav
2018-09-03 00:10:51 45357 [HttpClient] Content-Type: application/xml; charset=utf-8
2018-09-03 00:10:51 45357 [HttpClient] Content-Length: 198
2018-09-03 00:10:51 45357 [HttpClient] Depth: 0
2018-09-03 00:10:51 45357 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?><propfind xmlns="DAV:" xmlns:CAL="urn:ietf:params:xml:ns:caldav" xmlns:CARD="urn:ietf:params:xml:ns:carddav"><prop><current-user-principal /></prop></propfind>
2018-09-03 00:10:51 45357 [HttpClient] --> END PROPFIND (198-byte body)
2018-09-03 00:10:51 45357 [HttpClient] <-- 403 Forbidden https://cloud.disroot.org/.well-known/caldav (172ms)
</body>
</html>
2018-09-03 00:10:51 45357 [ui.setup.DavResourceFinder] Well-known URL detection failed
2018-09-03 00:10:51 45357 [ui.setup.DavResourceFinder] No principal found at user-given URL, trying to discover
2018-09-03 00:10:51 45357 [ui.setup.DavResourceFinder] Looking up SRV records for _caldavs._tcp.cloud.disroot.org
2018-09-03 00:10:51 45357 [ui.setup.DavResourceFinder] Didn't find caldav service, trying at https://cloud.disroot.org:443
2018-09-03 00:10:51 45357 [ui.setup.DavResourceFinder] Trying to determine principal from initial context path=https://cloud.disroot.org/.well-known/caldav
2018-09-03 00:10:51 45357 [HttpClient] <-- 403 Forbidden https://cloud.disroot.org/.well-known/caldav (174ms)
</body>
</html>
2018-09-03 00:10:51 45357 [ui.setup.DavResourceFinder] No resource found
2018-09-03 00:10:51 45357 [HttpClient] <-- 405 Not Allowed https://cloud.disroot.org/ (191ms)
2018-09-03 00:10:51 45357 [HttpClient] Content-Length: 166
</body>
</html>
2018-09-03 00:10:51 45357 [HttpClient] <-- END HTTP (166-byte body)
SOFTWARE INFORMATION
Package: at.bitfire.davdroid
Version: 2.0.3-ose (244) from Aug 29, 2018
Installed from: com.google.android.packageinstaller
JB Workaround installed: no
CONNECTIVITY (at the moment)
Active connection: WiFi, CONNECTED
CONFIGURATION
Power saving disabled: no
android.permission.READ_CONTACTS permission: denied
android.permission.WRITE_CONTACTS permission: denied
android.permission.READ_CALENDAR permission: denied
android.permission.WRITE_CALENDAR permission: denied
org.dmfs.permission.READ_TASKS permission: denied
org.dmfs.permission.WRITE_TASKS permission: denied
System-wide synchronization: automatically
SQLITE DUMP
android_metadata
| locale |
| en_US |
services
| _id | accountName | service | principal |
sqlite_sequence
| name | seq |
homesets
| _id | serviceID | url |
collections
| _id | serviceID | type | url | privWriteContent | privUnbind | forceReadOnly | displayName | description | color | timezone | supportsVEVENT | supportsVTODO | source | sync |
SYSTEM INFORMATION
Android version: 7.0 (NPNS25.137-93-14)
Device: motorola Moto G (5) Plus (potter)
--- END DEBUG INFO ---
