example
longer
example
here
Nextcloud version (eg, 12.0.2):15.0.3
Operating system and version (eg, Ubuntu 17.04): Alpine Linux on Docker
Davdroid aka DavX^5 cannot login to the caldav service. It complains about not being able to authenticate and a missing Authority: Bearer header. It worked fine in earlier versions.
- Install the wonderfall docker image.
- Setup a docker-compose similar to mine
- Try to add the caldav service to davdroid/davx^5
[core] Warning: Login failed: 'username' (Remote IP: 'ip')
from ip at 2019-02-08T06:15:24+01:00
My docker-compose for nextcloud:
nextcloud:
image: wonderfall/nextcloud:latest
container_name: nextcloud
network_mode: bridge
environment:
- UID=1000
- GID=1000
- UPLOAD_MAX_SIZE=10G
- APC_SHM_SIZE=128M
- OPCACHE_MEM_SIZE=128
- MEMORY_LIMIT=512M
- CRON_PERIOD=15m
- DB_TYPE=mysql
- DB_NAME=nextcloud
- DB_USER=nextcloud
- DB_HOST=mariadb
depends_on:
- mariadb
links:
- mariadb
- mail
volumes:
- nextcloud-data:/data
- nextcloud-config:/config
- nextcloud-apps:/nextcloud/apps2
- nextcloud-themes:/nextcloud/themes
labels:
- "traefik.enable=true"
- "traefik.port=8888"
- "traefik.frontend.rule=Host:nextcloud.domain.tld"
- "traefik.frontend.headers.STSSeconds=31536000"
- "traefik.frontend.headers.referrerPolicy=strict-origin"
- "traefik.frontend.redirect.permanent=true"
- "traefik.frontend.redirect.regex=https://(.*)/.well-known/(card|cal)dav"
- "traefik.frontend.redirect.replacement=https://$$1/remote.php/dav/"
'datadirectory' => '/data',
'apps_paths' =>
0 =>
'path' => '/nextcloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/nextcloud/apps2',
'url' => '/apps2',
'writable' => true,
'instanceid' => '',
'passwordsalt' => '',
'secret' => ',
0 => 'nextcloud.domain.tld',
'overwrite.cli.url' => 'https://nextcloud.domain.tld',
'config_is_read_only' => true,
'version' => '15.0.3.0',
'dbname' => 'nextcloud',
'dbhost' => 'mariadb',
'mail_from_address' => 'administrator',
'logtimezone' => '',
'logdateformat' => 'Y-m-d H:i:s',
'dbuser' => 'oc_admin',
'dbpassword' => 'password',
'mail_smtpmode' => 'smtp',
'loglevel' => 2,
'theme' => '',
'trusted_proxies' =>
0 => 'IPnet',
'mail_domain' => 'domain.tld',
'mail_smtphost' => '',
'mail_smtpport' => '25',
And the nginx config file:
server {
listen 8888;
root /nextcloud;
fastcgi_buffers 64 4K;
# https://docs.nextcloud.com/server/14/admin_manual/configuration_server/harden_server.html?highlight=security#enable-http-strict-transport-security
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload";
# https://docs.nextcloud.com/server/14/admin_manual/configuration_server/harden_server.html?highlight=security#serve-security-related-headers-by-the-web-server
add_header X-Robots-Tag none;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
include /nginx/conf/fastcgi_params;
fastcgi_split_path_info ^(.+\.php)(/.*)$;
fastcgi_pass unix:/php/run/php-fpm.sock;
fastcgi_intercept_errors on;
fastcgi_read_timeout 1200;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
location ~* \.(?:css|js|woff2?|svg|gif)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;";
add_header X-Frame-Options "SAMEORIGIN";
access_log off;
location ~* \.(?:png|html|ttf|ico|jpg|jpeg)$ {
access_log off;
