Hi all,
Nextcloud version (eg, 20.0.5): 24.0.3.2
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
PHP version (eg, 7.4):
since some days my iOs devices are not synchronizing anymore.
MacOS devices are still synchronizing.
Maintenance mode is set to false, but sabre is still reporting errors that the system is in maintenance mode.
Does anybody give me a hint how to fix this?
TIA
Harald
- Sync from an iOS device
Debug log reports:{“reqId”:“YvO6iXwLzafDVzTsWa@5AwAAAAo”,“level”:0,“time”:“2022-08-10T14:02:49+00:00”,“remoteAddr”:“a.b.c.d”,“user”:“–”,“app”:“webdav”,“method”:“PROPFIND”,“url”:“/remote.php/dav/”,“message”:“**Das System befindet sich im Wartungsmodus**.”,“userAgent”:“iOS/15.6 (19G71) accountsd/1.0”,“version”:“24.0.3.2”,“exception”:{“Exception”:“**OCA\DAV\Exception\ServerMaintenanceMode**”,“Message”:“**Das System befindet sich im Wartungsmodus**.”,“Code”:0,“Trace”:[{“file”:“/abc/3rdparty/sabre/event/lib/WildcardEmitterTrait.php”,“line”:89,“function”:“checkMaintenanceMode”,“class”:“OCA\DAV\Connector\Sabre\MaintenancePlugin”,“type”:“->”},{“file”:“/abc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:456,“function”:“emit”,“class”:“Sabre\DAV\Server”,“type”:“->”},{“file”:“/abc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:253,“function”:“invokeMethod”,“class”:“Sabre\DAV\Server”,“type”:“->”},{“file”:“/abc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:321,“function”:“start”,“class”:“Sabre\DAV\Server”,“type”:“->”},{“file”:“/abc/apps/dav/lib/Server.php”,“line”:352,“function”:“exec”,“class”:“Sabre\DAV\Server”,“type”:“->”},{“file”:“/abc/apps/dav/appinfo/v2/remote.php”,“line”:35,“function”:“exec”,“class”:“OCA\DAV\Server”,“type”:“->”},{“file”:“/abc/remote.php”,“line”:166,“args”:[“/abc/apps/dav/appinfo/v2/remote.php”],“function”:“require_once”}],“File”:“/abc/apps/dav/lib/Connector/Sabre/MaintenancePlugin.php”,“Line”:86,“CustomMessage”:“–”}}
Translation: Das System befindet sich im Wartungsmodus -> The system is in maintenance state
'passwordsalt' => '...',
'secret' => '...',
0 => '...',
1 => '...',
'datadirectory' => '/var/www/vhosts/.../.nextcloud/data/...',
'version' => '24.0.3.2',
'overwrite.cli.url' => 'http://...',
'dbname' => '...',
'dbhost' => '...:3306',
'dbuser' => '...',
'dbpassword' => '...',
'instanceid' => '...',
'theme' => '',
'loglevel' => 3,
'mail_from_address' => 'noreply',
'mail_smtpmode' => 'smtp',
'mail_domain' => '...',
'mail_smtpauth' => 1,
'mail_smtphost' => '...',
'mail_smtpport' => '465',
'mail_smtpname' => 'noreply@...',
'mail_smtppassword' => '...',
'mail_smtpsecure' => 'ssl',
No errors reported here
